Salta al contenuto principale
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
20 Domande Visualizza tutte
How to change my tablet charching port.
because, when i try to charcge it it won't work
Questa è una buona domanda?
Punteggio 9
Aggiungi un commento
2 Risposte
Risposta Più Utile
There is a possibility that it may not be the charging port, but a bad battery. If it is the battery, you have to replace it with a new one. Please use our guide on how to replace the battery:
Asus MeMO Pad HD 7 Battery Replacement
If it is the charging port that is defective, you must follow our guide on how to detach the motherboard:
Asus MeMO Pad HD 7 Motherboard Replacement
Once you remove the motherboard, you are going to have to remove the solder at the four soldering points that keeps the charging port in contact with the motherboard. With your new charging port, you must solder it using the four soldering points on the motherboard.
If you do not want to solder the charging port off and solder a new one in its place, we recommend buying a whole new motherboard. Luckily, we sell the motherboard on iFixit:
ASUS MeMO Pad HD 7 Motherboard
Immagine Main circuit board assembly
Prodotto
$29.99
Immagine Asus MeMO Pad HD 7 Battery
Guida
Difficoltà:
Facile
15 minutes
Immagine Asus MeMO Pad HD 7 Motherboard
Guida
Difficoltà:
Moderato
Punteggio 2
2 Commenti:
Related to this answer/scenario, would replacing the whole motherboard be equivalent to resetting the tablet? In other words, is the device memory included on the board such that replacing it would be a clean slate? Thanks!
da
Yes it is, it's basically like getting a brand new tablet so you will need to reinstall all of your apps and you will lose anything that you haven't backed up. Anything saved to your memory card will be fine as you can just swap that across.
da
The the charging port need replacement
Punteggio 0
Aggiungi la tua risposta
Ivan Rafael Ramirez Romero sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 10,532
