Salta al contenuto principale
Released in April of 2006, the S4011 was built for everyday tasks such as word document processing and internet browsing.
3 Domande Visualizza tutte
want to upgrade wi-fi card
The wi-fi card on my A105 works, but is slow. I see that there are "N rated" cards available for as little as $20 but I have no idea if they will fit in my A105 model. Is there a standard for factor (size, shape, number of "pins," etc) for all wi-fi replacement cards? if not, how might I go about getting the proper card? Thanks in advance! Jami
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
I think your best bet here is to use a USB WiFi adapter Vs trying to upgrade your internal unit.
Here's a good write up on the very latest 802.11ac adapters: Tested: We push six 802.11ac Wi-Fi USB adapters to the limit. Depending on your OS version you may not be able to use these in which case you'll need to checkup the older 802.11n adapters.
Punteggio 1
Aggiungi la tua risposta
Jami Francis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 287
