Salta al contenuto principale
Il laptop Gateway P5WS0 è commercializzato anche come laptop Packard Bell in alcuni paesi. Il P5WS0 fa parte della serie NV di Gateway ed è identificabile dal modello NV57H58u.
How do I replace the keyboard?
How do I replace the keyboard on my laptop? I know that there is a tear on the left shift key pad that I found after removing the key to clean a sticky substance that I thought was the issue.
Questa è una buona domanda?
Punteggio 1
1 Commento:
how would ou clean under the trackpad on this laptop? i have the same one and im wondering cause i need to clean mine
da
Aggiungi un commento
1 Risposta
Hi Hurley,
As far as i know with the knowledge of the same model but from Packard Bell this laptop has sort of a "unibody" like a macbook.
U would have to remove the complete top cover by removing the screws sitting at the bottom and lift the top cover up as a whole to get to the keyboard.
Mind you that most of the times these top covers are extra mounted with clips so it might take a bit of effort to remove it. I would suggest to start from the front (the side of the touchpad) and move forward towards the back.
Hope this helps you in any way.
Punteggio 0
Aggiungi la tua risposta
Hurley sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 30
Tutti i Tempi: 1,500
