Salta al contenuto principale
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
Is there a way to replace the camera on the display?
Whenever I open Photo Booth or Skype, my MacBook says no camera can be found. Is there a way to replace the camera or check if a cable came loose on the motherboard?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
I've never seen the actual camera go bad. Most likely is a bad cable connection. Check step 6 of this tear down to make sure it's plugged in correctly. This is an easy fix. MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Assembly Replacement
Punteggio 1
Well since it's a unibody you have to remove the entire display assembly.
Punteggio 0
Aggiungi la tua risposta
patrick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 498
