Salta al contenuto principale
Smaller, thinner, quieter model of the Playstation 2 (SCPH-700xx) released by Sony in September, 2004.
Why is my game disk not spinning?
I had my Playstation 2 'stored' in a drawer of my room. When I decided to rehook it to play after possibly 3-5 years, it was very dusty. I took the time to make sure I blew out remaining dust inside the console and on the surface, along with making sure my game disk was in decent condition to play. I found that my disk was not being read properly no matter how many times I tried, so I looked into detail to see if the laser was working, or if it was spinning. Surprisingly enough, the disk will not spin! The break that will release the disk does release it when the lid is closed, and the console should be detecting the lid is shut, but it just won't spin. It won't with movie DVDs, CDs, or game disks. The first time I tried it, the game worked fine, but then I tried making a new save from it, then the game froze. Therefore, it surely was spinning until the sudden stop after trying to make a new save. If further detail is needed, I will be glad to try to add it.
Questa è una buona domanda?
Punteggio 7
2 Commenti
It wouldn't spin, even after cleaning dust so I put a disc in an it keeps goingetting to systeme browser so I left it with disc in and when I came back the game was now showing. Any idea why?
da
I'm having same issues too except nothing is turning over. I pushed down both sensors and no spin except for a loud buzzing. I've replaced the laser no spinning. All ribbon cables are intact. Not sure what to do.
da
Aggiungi un commento
6 Risposte
Risposta Più Utile
Hey mate, first off. I know you have tried the brake release, but have you tired both (there are two that need to be pushed down to allow the disk spin). There is one near the power switch. The other one is towards the back, left of the laser assembly. This photo shows there location;
http://www.richspsxparts.com/howto/lidcl...
If that isn't it, it could be a faulty laser or motor problem. It could be a problem with its wiring (the motors ribbon cable sometimes is the problem, so inspect that) or it has simply died. If not a motor problem. It could also be that the laser can't read the disk/detect there is one, the motor won't spool up/spin. The laser is what tells the motor to pin, go a set speed etc.
If you want to try a new laser etc, you will need your PS2's model number. This guide should help you out, to insure you order the correct components;
http://www.ebay.com.au/gds/How-To-Determ...
Hope this gives you something to go on/help you.
Punteggio 1
3 Commenti:
Thanks for you help, but I managed to fix it. The problem was, there was too much dust and a small piece of rubber trapped inside the console itself. I managed to take it apart and clean it off. It works fine now. (When I blew out the dust as mentioned above, I had not actually taken the console apart, I just blew in the holes inside the lid)
da
That's awesome mate. Dust is the root evil of all electronics. I'm glade you were able to get it back up and running. Happy gaming :)
da
for me it didn't work so well still wont work i ordered new laser spindle assembly. think it just died living on the uk had to purchase one from USA witch was a bump but worth it even if i bought a ps2 replacement it could of easily done the same thing.
da
Parti & Attrezzi Popolari
It goes back an forth when the lazer comes to it what's wrong
Update (02/12/2016)
My moter does not turn properly it goes back an forward on my PlayStation 2
Punteggio 1
Recently I pulled out my PS2 to work further on it since the parts came in. I replaced the battery and the motor. By the way don’t order any of motors here in the US because the ribbon cable is way too short. I had to order the correct part from China and they are becoming increasingly rare. Unless you pull one out of a DVD player or something. The laser works just fine even after replacing it. Even after installing a new motor nothing happened, no spin just a quick buzz sound which to my theory is the motor attempting to spin but unable due to a minor error that makes it spin. Best chance, it has to be the fuse. The fuse is located behind the motherboard which requires disassembling. This fuse is not your typical tube like fuse that you can just pluck out. They are tiny little fuses soldered into the motherboard. I don’t have a diagnostic to tell whether or not the fuses are bad. The naked eye is unable to see between a good fuse or a bad fuse. The fuse is what makes the motor function and if a fuse goes bad then it simply will not work. By the way there is multiple fuses so this kind of work gets real technical. Either find somebody who works on games consoles or start doing the research for repairs on Youtube and do the work yourself.
Punteggio 1
1 Commento:
Also just a tip. If the motor does not spin but the laser works then that means that both sensor gates are functioning.
da
My ps2 got throad at the wall and it broke and the disc of the part broke
Punteggio 0
Same prollem here, ive been looking for my ps2 and my dad put it in a bin on top of 500 lbs of stuff. It will not spin.
Punteggio 0
It probably was to dusty plus I have not used it in about a year and it's very old
Punteggio 0
Aggiungi la tua risposta
Kayleigh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 128
Tutti i Tempi: 77,496
