Salta al contenuto principale
Repair and disassembly guides for remote controls.
does not communicate with devices
unit was working ok. screen still lights up ok. none of the buttons work. suspect infrared transmitter or its driver. cant locate any repair manual. i like the unit (when it works) because it has a charger but would not buy another logitech harmony - too expensive, unreliable & no repair manual.
any advice?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I would first make "my" standard IR test
use a cell phone with a build in camera - activate the camera
point with the remote control into the camera lens and press any button on the remote
look at the cell phone screen while pressing the buttons
if you see a white flashing light - the remote control sends an IR signal.
Punteggio 2
Preparati per le riparazioni future
I'm not sure about the model you have, but I had trouble with a Harmony 880, as have many others. I wrote a guide on how to replace the IR LED's.
Guide is here.
Punteggio 0
Aggiungi la tua risposta
COL BURG sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,267
