Salta al contenuto principale
How to fix low VRAM?
Hi everybody,
Many thanks to Machead3 for your answer ! Well, you're right, the Macbook Core 2 Duo Model A1211 is built with 128 Mo of VRAM.
But as I said, the graphic chipset has been replaced after the overheating, but now, the bad thing is that I have just 5 Mo of VRAM instead of 128 Mo.
Is the VRAM comes from graphic chipset or from memory (RAM) modules ? Or perhaps from another component on the logic board ?
Many, many thanks to all the community for all answer about it.
Kind regards from France
Yves
PS: I'm sorry if I make any mistake... I'm a newbie for posting on the site.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Without knowing what GPU/VGC you put in the box I can't answer your question exactly. Generally however "shared VRAM'' is a more recent development and most likely not to be a part of your machine.
The VRAM is either on the card, or when not on the card comes from the machines RAM, only since about 08 has there been both/or switching of VRAM possible.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
yjusserand sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 477
