Salta al contenuto principale
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
How do you remove LCD from case
It looks like around the hinge the LCD casing is broken. I would like to replace the casing without replacing the whole LCD.
How do I open the casing so I can see which side is broken.
I can be reached at
Thank you for your help
Erik
Questa è una buona domanda?
Punteggio -1
1 Commento
machead3
Great Link
It's exactly what I needed
Thank you
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Once you get the top off the bottom
It should be very evident which one is broken see: http://www.PowerBookmedic.com/mac-repair... Display removal followed by hinge replacement.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Punteggio 2
Parti e strumenti correlati
Acquista tutti
It's a difficult repair to replace the LCD casing on the PB Titanium since it is glued to the LCD and hard to glue it back in place. You could find a whole replacement display assy for cheap if you search the web (ebay, craigslist, etc).
Punteggio 1
Aggiungi la tua risposta
Erik sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,891
