Salta al contenuto principale
Model A1318 / 32 or 64 GB capacity
20 Domande Visualizza tutte
no wifi or bluetooth
I purchased a used device that wasn't working. After restoring it seems to work fine...except it has no wifi or bluetooth. I'm assuming the chip is missing or defective. can the wifi chip be replaced? why are there so few parts for the 3G?
Questa è una buona domanda?
Punteggio 3
1 Commento
How to fix wifi and bluetooth problems on Htc one?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Great News!!!
The 99% alcohol isopropyl "bath" worked. Either that or it was simply the tear down that jogged something free (or back together).
I just REMOVED THE BATTERY FIRST, unscrewed both the lower and upper IC boards, loosened all the ribbon cables so the lower IC board could be flipped up (not removed completely), unhooked the cable from the power/volume buttons (didn't remove the button assembly screws at all) and then gently washed the whole works with alcohol and a soft small bristle brush. Then blew it off VERY well but gently (let it dry dry dry...especially underneath the plastic connections attached to the IC board).
I left the upper IC attached (it seemed glued on there pretty well and I didn't want to force anything since this is my first tear down of a 3rd Gen).
Put it back together, DFU'd it, restored it, tested it and was VERY excited to find that both the WIFI and the Bluetooth areas are now both active and usable. I REALLY hope they stay that way for a long long time to come.
Good luck.
Punteggio 1
1 Commento:
I haven't been so lucky. mine stopped working and i took it apart. it does have the chip so whatever (water probably) damaged it probably shorted something. thanks for the reply i'll try the alcohol bath.
da
Hello Mark,
I'm facing this exact issue. I bought it "as is" on eBay water damaged and in need of a new LCD. The lcd is on now and looks sweet. All is well...but for... in the settings it shows a greyed out section for bluetooth and wifi. I did the restore a few times and still nothing.
In answer to your question I think the wifi, bluetooth and antennea for both are all connected to the logicboard and not replaceable as a separate unit. But I may be wrong.
I'm hoping that maybe some water/liquid might have crossed some connections and a good alcohol bath might fix the issue.
Punteggio 0
Aggiungi la tua risposta
Mark sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 10,061
