Salta al contenuto principale
Repair guides for the variations of the Compaq Presario CQ62 laptop. This brand was manufactured from 1993 to 2013, and was owned by HP from 2002 to 2013.
20 Domande Visualizza tutte
there is power but only a black screen
it turns on but it's only a black screen and the cap locks keeps flashing
Questa è una buona domanda?
Punteggio 13
3 Commenti
My screen is black the windows logo comes up but then it goes away and the screen is black can I fix this
da
How do I get my screen to come up
da
My compaq 160 black screen
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Sammy Soto, try this firs. Disconnect all power sources, battery, plug, usb devices, then hold down the power button for a minute to clear residual charge. this should reset your bios. If it does start up go to the diagnostic tab and run the hard-drive and memory Tests. See what it shows. This could be as simple as a bad memory module to as bad as a failed CPU. Check here for the blink codes. Hope this helps, good luck.
Punteggio 3
10 Commenti:
Thank you. I had the same problem. Did what you explained and it worked! I really appreciate it. G
da
Me too! Thanks a lot. As a non-techie person, I appreciate not having to go to the repair shop.....again!!
da
doesnt work for me any other tips?
da
billyjoewitehira, same blink codes? You tried an external monitor? what have you tried?
da
Worked for me thanx
da
Mostra altri 5 commenti
I came upon this question a bit late. If you have no display when powering up the laptop on both the built in LCD monitor and a monitor connected to the VGA port the issue is a bit more serious.
The cause of the issue is a clogged radiator in the exhaust fan.
That being said depending on how quickly you address the issue the fix can be simple or quite complex.
Either way you will be disassembling the laptop and removing the cooling fan and heat pipe assembly from the mother board. With the assembly removed clean all the old heat-sink compound from the two (2) heat sinks on the cooling pipe assembly as well as the two (2) ICs they mount to. Disassemble the fan and with a soft brush or "canned air" completely clean the radiator fins.
If the problem is addressed right away by cleaning about 6 out of 10 machines need nothing else but reassembly with fresh heat-sink compound applied.
If the problem is not addressed right away the repair is not for the feint of heart.
To repair- After removing the heat pipe assembly mentioned above you will see the CPU an a smaller IC on the mother board. You will need to use a hot air or infra red reworking station or it's equivalent to heat the smaller IC (it is your graphics processor) to about 200- 220 degrees Celsius for two (2) to three (3) minutes to re-flow the solder connections and then reassemble as above.
All that because the fan was clogged and has heated the graphics IC enough to loosen the connections between the motherboard and the IC.
Hope this helps you fix the problem and understand why it occurs.
PC fix mantra- Clean your PC cooling system and back up your data regularly.
Punteggio 2
2 Commenti:
It worked. Now computer is up again.
da
I need to knpw whic IC to heat up, is there ap picture of it, I dont want to heat the wrong one.
da
Change CR3032 battery, my computer been black screen for months. I've done hard reset until it stop working. Decided to check it with another monitor and it was working. Disconnected from monitor went back to black screen. Took back off seen the coin battery replaced it been working ever since.
Punteggio 1
1 Commento:
This worked perfectly! Thank you!!!!
da
Aggiungi la tua risposta
Sammy Soto sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 23,502
