Salta al contenuto principale
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
My LG G2 LCD screen is coming off after replacing it?
Hi,
I have been fixing my LG G2's LCD+Digitizer and I think the stickytape didnt do a good job, is there a way ( maybe glue or something?) to make the screen stick better to the ducktape without re-opening the whole phone..? I had a hard time doing that, lol.
Thanks
Questa è una buona domanda?
Punteggio -1
1 Commento:
I have the exact same problem with my G2. Repairer said the tape is spongy and there's nothing they can do about it. But surely there must a fix for it? ? Please help!!
da
Aggiungi un commento
1 Risposta
I had the same problem with mine. Is it that bottom right corner? You're going to have to disassemble the phone in order to get tape under there to stick properly. I would not attempt to adhere the phone without fully removing the screen.
Your repairer should do this for you as this is a failure of their repair. How long has it been since you got it replaced? Was there no warranty on the replacement?
Punteggio 0
1 Commento:
Well, I did the repair myself with the sticky tape. Yes it is the right and left bottom. I can see the white LED lights when its dark. The top part is fine, there was enough space to attach stickytape on it.
Would u recommend using superglue with a narrow end to glue it in both corners? There is a pretty good space to do it, if i could find glue that goes trough a small needle to be verry carefull.
da
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,088
