Salta al contenuto principale
Released December 8, 2009, the Toshiba Satellite L455D-S5976 has a silver upper case and a silver/black lower case. It has a 15.6 inch screen with TOSHIBA written in all capital letters on the back of it.
How do I replace the Inverter
how do I replace the inverter?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
take the upper cover, unscrew the hinges. be careful to disconnect the wifi antenna cables and the lvds cable. take the screen out of the chassis now. on the screen bezel, under some rubber feet there are screws, this screws, along with plastic clips hold the bezel. take them out. you are in. now is just disconnect some cables and you are good to go
Punteggio 0
Parti e strumenti correlati
Peggy, check this video. At around 1'30" you can see the inverter.
Punteggio 0
Aggiungi la tua risposta
Peggy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 281
