Salta al contenuto principale
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
not charging and not recognised in itunes
My Ipad3 doesn't show the lightning symbol when connected to wall charger. but after 10hours it charges 8%. I tried with another wall charger, but the result was same. till 2days ago it was charged to 100% and worked fine. what would be the problem...battery or connector strip, fuse or some other else. when connected to pc it says usb not recognized. I think the cable is good b`cause it is working fine with my iphone 4s ie..charging and connecting to iTunes. Finally I got it charged to 100% without charging icon afer 4days ie..72 hrs continuous charging. now the battery discharge is normal. can I please know the actual problem.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Sounds like it is probably your battery.
Punteggio 0
Aggiungi la tua risposta
alaparthisudhir sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 365
