Salta al contenuto principale
LCD brightness flickers when moving the monitor - How 2 fix?
When I open the monitor, it feels like there is a "short" in the power supply to the LCD... as I move the monitor, the brightness flickers dark / light until I stop moving it. I have to wiggle the monitor to get it to display bright or move it into a different position. The hinge also feels very loose inside. I want to know...is there a ribbon cable in there that may be damaged / pinching? Can I buy from you and replace it myself and tighten the hinge as well?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I would make sure to replace the inverter cable before it shorts in the hinge and damage the logic board. Meanwhile don't play too much with the lid.
Punteggio 2
1 Commento:
agreed +
da
Preparati per le riparazioni future
Acquista tutti
I'd suggest an issue with the inverter cable. It's located at the left hinge.
Punteggio 1
Aggiungi la tua risposta
Joey Morelli sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,243
