Salta al contenuto principale
Also known as LG Optimus P970 schwarz in Germany, released May 2011.
Is it possible to have a RAM Upgrade for Mobiles
Hi ,
I was just thinking will it be possible to upgrade LG P70 RAM .
I really can't afford to buy new phone , so if i can upgrade RAM form 512 MB to 1GB . IT will be great!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
5 Risposte
Soluzione Prescelta
rahul razdan, the RAM is contained in an IC which is soldered onto the logic board. It is not possible for the regular DIY'er to change that IC. Unless you have a bigger RAM chip with the exact layout and ball grid array, and unless you know how to reball such an IC, it is not possible. Even if it could be done, the firmware might not access the additional memory address. Hope this helps, good luck.
Punteggio 2
2 Commenti:
oldturkey03 , thanks
da
Mobile repair
da
The only way to have more ram is to buy a better phone I first had a free phone and had 512 mb. then I paid 49.99 and now have 1.9 gigs and still is not enough. Its like money the more you make the more you spend hense the more you need !? Go figure
Punteggio 1
Mere mobile ki ram kam hai increase kar do
Punteggio 1
3 Commenti:
Google Translate:
my mobile ram is low please increase it
Satyam Yadav, please read the other two answers to this question. RAM is always soldered to the logic board and is not user replaceable.
da
Please increase my ram
Please increasey mobile ram
da
Mrinmoy malakar tumhare ram increase nai ho sakta kyu ki wo logic board se attach rehta hai. acha hoga ki tum ek new phone jada Ram wala le lo
da
I want to increase the ram of my phone
Punteggio 1
1 Commento:
@bluemoon46769 double check the answers. The RAM is contained in an IC which is soldered onto the logic board. It is not replaceable by the normal DIY'er. You cannot increase your RAM
da
Meri phone ka ram badadua
Punteggio 0
Aggiungi la tua risposta
rahul razdan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,018
