Salta al contenuto principale
A Type 5491 shaver by Braun with many similarities to the models 7570, 7564, 7664, and 7690.
cannot get it to turn off
it has 3 options to operate . it will operate on all 33 but will not come down to off
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
This might help: Braun Shaver Model 7680 Battery Replacement
Punteggio 2
Parti e strumenti correlati
Open the case as per tutorial to change the battery. I had similar issue but just not turning on, case was full of hair which prevented the correct operation.
Punteggio 0
The slider switch on mine has failed too. It jams in one or two 'up' positions that make no difference. Mine is the Braun 7505, but essentially the same as many others. YouTube has one video on the topic, solving the problem with a hammer. Unhelpful. :-/
Anyone tackled the sliding switch problem? Certainly not a battery issue.
Thx.
Punteggio 0
1 Commento:
@ardwych see if this gets you to where you need to be with that switch.
da
Aggiungi la tua risposta
Harry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 7,038
