Salta al contenuto principale
The Nexus One (also known as the HTC Passion and Android Dev Phone 3) is a smartphone from Google (manufactured by HTC) that runs the Android operating system.
Where does the rubber microphone channel go?
In replacing the screen on my nexus one, I let the rubber mirophone channel fall out. Does anyone know where to place it?
Questa è una buona domanda?
Punteggio 2
1 Commento
did you figure this out? lol im having the same problem...
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It lines up with the hole in the bottom of the phone. That's the long rectangular rubber part. The round part actually pressure fits over a round thing near the bottom of the motherboard. Once you find it it will make sense because it will fit perfectly around the round thing and extend exactly to where the hole is on the bottom of the housing.
It's a pain in the butt to get back on, especially when I reassemble the phone and I look down and see it sitting in my parts dish still, I'm like FUUUUUU-
Punteggio 0
1 Commento:
I left it out and the phone works fine now.
da
Preparati per le riparazioni future
Risposta Più Utile
You can try checking the teardown to see if you can figure it out.
Punteggio 1
Aggiungi la tua risposta
nina sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,688
