Salta al contenuto principale
adding ram
hello, love the site, I have ordered 2gb of ram and see where my machine can run up to 3gb of ram. I currently have 1 gb of ram that it came with installed, is it as simple as adding the new ram to a open slot if thats the case? I have not opened the unit yet because i lack the proper tools. Thank you so much.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Hello! Thanks for your kind words. We love the site too!
You have 2 RAM slots in your machine. To max out your RAM, you will need one 2 GB chip and one 1 GB chip. It is possible that your machine has two 512 MB chips to equal a total of 1 GB. You will, however, need to remove one of those to insert the 2 GB chip.
Honestly, you will not see a remarkable performance difference between 2.5 GB and 3 GB though (so it might not be worthwhile to switch out a 512 MB chip with a 1 GB chip after you have the 2 GB chip installed).
I hope this helps!
Punteggio 3
Bad idea with the RAM though, you shouldn't have unblanced RAM, so instead of getting a 2GB and adding that with 1Gb and 2gb, get two 2GB for a total of 4GB, i don't know about iFixit, (if they'll purchase it), but i know that OWC will give you a rebate on RAM.
Punteggio 0
Great topic and great site. I upgraded my MacBook Pro RAM several years ago. Please, please pay attention to the angle at which the chip seats; it's finicky.
How much RAM is the MacBook Pro 17" able to recognize? I thunk it was 3GB but, now I'm wondering if Snow Leopard has the ability to exceed that. Your thoughts are appreciated.
Punteggio 0
2 Commenti:
check apple's site, just google install ram macbook pro, they have a thing which let's you see for each version through the years
da
thanks for the heads up!
da
That was a tremendous answer, thanks so much.
Punteggio -1
2 Commenti:
You're welcome! Glad to help.
da
Accept it then
da
Aggiungi la tua risposta
dmaus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,158
