Salta al contenuto principale
The Iconia A110 is an Android tablet released by Acer in October, 2012. It features a MicroSD slot, HDMI port, a 7" multi touchscreen display, and a 2.0-megapixel front camera.
How to fix the power button?
I cannot turn on and off the tablet because the power button is jammed. I need to know how to remove the power button and replace it without damaging the tablet itself. Please help.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
4 Risposte
Risposta Più Utile
Kyle, here is a decent teardown. Looks like the power button sits on a flex. you may need to open it and see if you reattach it. Best is to open it up and take a look at what has failed. Hope this helps, good luck.
Punteggio 3
Parti & Attrezzi Popolari
Kyle,
Take a look at the power button repair guide.
This should lead you through the steps on how to remove the power button.
Hope this helps!
Punteggio 1
Hi ifixit
Have p problem with ny Iconia A1.
The microSD slot is faulty.
How do i open the unit for inspection?
Punteggio 0
Where can you get the part???
Punteggio 0
Aggiungi la tua risposta
Kyle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,987
