Salta al contenuto principale
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
How to replace the digitizer?
I read the guide and watched a few youtube videos, but when I tried to replace a cracked iPod nano 7g digitizer I couldn't get the LCD out. I ended up breaking the thin metal frame around it and scratching it, as well as bending it. I successfully removed the digitizer. How do you get the entire display assembly out? Also, will an iOpener help me remove the small back piece (above bluetooth antenna), as I had trouble with this as well? Thank you.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
The iOpener should help. Make sure that the spudger is under the entire display assembly to prevent bending the metal midframe.
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
JT7 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 420
