Salta al contenuto principale
Series of 15.6" Windows laptops by Acer directed toward casual users.
7 Domande Visualizza tutte
it will not boot but I can enter bios
I bought this laptop second hand as a dead unit, on examination I found that the I3 CPU had died, put a known good CPU in and turned on, Great, it started the POST, I get the Press f2 or f12 options, then the Acer Logo flashes up for a second or two then it hangs with the cursor in the top left of the screen, can anyone give help/advice?
PS:I can enter bios and see all devices, IE, Hard drive, CD rom and RAM, it can also see any USB devices I connect.
Things I have tried include removal of all USB devices, use of known good Ram, even removed the wireless module.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Have you removed the CD rom and the hard drive ? and then see if it will boot farther ?
Punteggio 0
Basically probably ur boot.ini file broken or some necessary files ar mising. If you start ur pc with any boot disk like windows xp 7 8 and install new windows. I believe your problem will be fixed.
Punteggio 0
Aggiungi la tua risposta
Frank Carr sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,190
