Salta al contenuto principale
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
How to get USB 2.0 on this model?
Please inform whether it is possible to get USB 2.0 via extension card, and if so, where to get one.
There are people claiming that hard-wiring inside the machine effectively will prevent any buscard solution. Also, there seems to be restrictions on buscard types working on this model.
I'll be ever so grateful for tips, as info so far seems both contradictory and confusing.
Newcomer
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
I've never tried one of these, but you can get a Firewire to USB2 converter:
http://cgi.ebay.com/Male-Male-USB-2-0-Fi...
Punteggio 4
4 Commenti:
Agreed +
da
yeah good workaround
da
This is a male to male.. just pointing that out
da
Yeah, you're logic board won't be able to handle USB 2.0, so it's a no go.
Punteggio 0
I'm pretty sure theres a PCMCIA port on your PowerBook. Try this:
USB 2.0 PCMCIA Cards
Punteggio 0
3 Commenti:
This is a PowerBook, not a MacBook, all MacBooks have usb 2.0
da
I meant PowerBooks. I think none of the MacBooks have PCMCIA card ports
da
You should update your answer to say PowerBook instead of MacBook then... ;)
da
Aggiungi la tua risposta
BELarsen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 750
