Salta al contenuto principale
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Internal keyboard and trackpad intermittently not working
Sometimes on boot up trackpad and keyboard will not work although a remote mouse plugged into USB port works ok but the keyboard still does not work.
If unit dropped about 3 inches on carpet (naughty i know ) works again, although sometimes stops working again whilst in use.
I suspect a loose cable/plug. Any ideas?
Questa è una buona domanda?
Punteggio 1
1 Commento
trackpad socket on logic board broken away from soldered joints
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yep, if you drop it and it works then a cable will be loose. Basically, make sure all the connections to the logic board featured in this guide are in properly.
Punteggio 1
1 Commento:
found trackpad socket had broken away from logic board on soldered joints
da
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
Petethefish sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,306
