Salta al contenuto principale
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Weird problems with the LCD. Very strange.
OK. I have this iPad 2 GSM that the LCD is glitchy. I let it die all the way and try to turn it on, the screen lights up like you would expect and tells you the battery is dead. So, I plug it in and let it charge for a day. Now press the power or home and the screen's backlight does not light up. You can see what is on the screen with flashlight, but no backlight. Let it sit until the battery dies and you are back to the dead battery notice with the backlight actually turning on. I have replaced the touch screen, the LCD, and the WiFi antenna. I have two different LCDs that do the same thing no matter what.
What cold be causing this strange behavior?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Your backlight filter is blown, you will need to solder a new on or take it to a shop that can do that type of repair.
Punteggio 1
1 Commento:
Is this a very common thing?
da
Parti e strumenti correlati
Acquista tutti
Hi dl200010,
When you say you replaced the LCD, do you mean ONLY the LCD? Why not try changing the digitizer as well?
Punteggio 0
1 Commento:
I replaced the digitizer because it was shattered. I replaced the WiFi antenna because it ripped while removing the digitizer, surprise surprise. I than replaced the LCD because it was not lighting.
da
Aggiungi la tua risposta
dl200010 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 183
