Salta al contenuto principale
A water-resistant fitness tracking wristband by Fitbit, released May 2013.
Battery in fitbit flex
Does the fitbit flex battery ever need to be replaced?
Questa è una buona domanda?
Punteggio 6
Aggiungi un commento
8 Risposte
Risposta Più Utile
I have had my Fitbit about 6 months and it will not light up? What do I need to do??
Punteggio 2
1 Commento:
I charged mine last night. green light was FLASHING from back. Now there is no display!
da
Check my comment on the teardown… Fitbit Flex Teardown
I think you can find a suitable 031012 battery if you look around & are willing to try dismantling it (which may destroy it).
Punteggio 1
So far no however the amount of sweat and gunk is awful. I clean my band every other day and clean the contacts carefully every few weeks.
Punteggio 0
Yes! I have had mine for about 19 months now and it only holds a charge for two days. Have not yet found out how to get the battery replaced.
Punteggio 0
==I have had my fitbit flex since Christmas eve and it takes hours to charge and wont hold a charge for even two days! Fitbit is going to get an angry e-mail shortly! ==
Punteggio 0
My flex is fully charged , all the lights are flashing but the screen on my iPad does not show any life. Have cleaned the terminals .
Punteggio 0
does battery ever need to be replaced ?
Punteggio 0
1 Commento:
Yes... but Fitbit have made sure it is not possible. The Fitbit flex is basically a disposable item. Once the battery has died (mine lasted 31 months) it is time to bin it and try another brand.
da
The time on my FitBit won’t adjust to the proper time… How can I fix it?
Punteggio 0
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 8,027
