Salta al contenuto principale
iFixit utilizza i cookie per migliorare le funzionalità del sito, analizzare il traffico e personalizzare gli annunci. Utilizzando il nostro sito, accetti l'uso dei cookie e l<link>Informativa sulla privacy</link>.
Lanciato il 24 ottobre 2011 / processori quad-core Intel Core i7 da 2,2, 2,4 o 2,5 GHz
Location of Sound Card on Logic Board?
Hello All!
Currently the MacBook Pro I am working on, has no sound. When it reboots, there is no start up chime and while in operation there are no audio devices detected. This leads me to believe there is a hardware issue with the sound card. I am curious to know where on the logic board the sound card is located. If possible a picture would be extremely helpful!
Thanks in advance.
Questa è una buona domanda?
Punteggio 3
1 Commento
Have you had any success? I've been having the exact same issue and since I'm not that qualified to be messing around with the logic board I was looking into it.
Thanks in advanced!
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hey thanks for the response.
So I think I may have found my issue, it seems that it may be unfixable but I am not 100%
Anyway in reviewing the logic board I see that I am missing something, the part is labeled ZJS7 and it sits just to the left of the cirrus audio chip. I have attached an image with the circled part I am missing.
So it obviously broke off somehow, my question is, is it fixable?? Or is the only solution a new logic board?
Thanks in advance!
Punteggio 3
3 Commenti:
Anybody returning to this post from the future please note Z-JS7 is a Vishay 47u 6.3v tantalum capacitor and replacement is easily done by anyone with a hot air workstation.
da
@scunnerdarkly hi. My macbook pro a2338 has no audio, Diagnostics are ok. Replaced speakers no luck. Could you please help
da
@alichaudhary You would have to do the same thing as @henninma did. Look your board over and see if you can identify anything odd looking. Then investigate deeper. In your case Cirrus CS42L83A IC is the audio jack codec. you also want to check what is being said by tomchai
da
Parti & Attrezzi Popolari
Acquista tutti
Henninma, first try to look into the system information to make sure the audio hardware is properly detected and listed. If they're there, the sound chip is working. If the chip is not detected, do a SMC reset and see if it works.
In the audio config, check the sounds are output by speakers rather than headphones or optical output. also look into the headphone jack and see if there is some red laser. The output is probably stuck on headphone or optical output. Clean the connector to resolve the issue.
The sound chip is the cirrus chip above the battery indicator connector.
Punteggio 0
Where can i buy ZJS7 chip
Punteggio 0
1 Commento:
@aleksaleksis ZJS7 chip is a Vishay 47u 6.3v tantalum capacitor. If you do a search with that information you will find that it is a 293D476X96R3D2TE3 Now use that number to find it online from a seller of your choice. There are hundreds of them
da
Aggiungi la tua risposta
henninma sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 22
Tutti i Tempi: 3,920
