Salta al contenuto principale
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
Change the HDD for a SSD
Is it possible, to remove the HDD and change it for a new SSD??
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The new Thin iMac's are different still again from the older models.
Replacing the HD with a replacement drive is one thing (like for like). Upgrading to a different storage type altogether is another matter. First you need to deal with the thermal sensor and the then need to think about the mounting hardware (if you didn't get a unit with a HD to start with).
I would recommend going the a hybrid drive (SSHD) like Seagates' offering Vs going with a straight SSD. Presently you can't upgrade the blade SSD units as you can't get a third party SATAe with a M2 interface yet as the M2 standard is still being defined. As soon as it is I think you'll see a flood of options.
You may want to also review this answer: Can I add a SSD myself
Punteggio 1
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
olivergrosser sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 651
