Salta al contenuto principale
Repair guides and support for cars manufactured by the Honda Motor Company.
Car jerks while accelerating.
My 2002 Honda Accord with 82500 miles on it jerks a bit when accelerating. Nothing happens to the speed but the rpm drops and then again increases and then the car picks up speed. What might be the problem ?
Questa è una buona domanda?
Punteggio 9
13 Commenti
what engine size is in your Accord? Any change in gas mileage? When was the last service?
da
The engine size is 2.3L 4Cyl., I haven't really looked at the gas mileage. The last service was done in May when the car had around 80K miles and now the car has around 82.5K miles.
da
Could i buy a transmission with a 2 year warranty and have it installed?
da
My hunda car won't pick up as I engaged it into drive mood even when i matched down the acceleration pedal. What might be the cause?
da
i have the same problem how did you fix it ?
da
Mostra altri 8 commenti
Aggiungi un commento
6 Risposte
Soluzione Prescelta
Could be a knock sensor or a loss of air inside the air box/tube that goes to the intake manifold. I would have the check engine light checked; just because it isnt on doesn't mean there isn't a code in the system. Most of the errors would give you a check engine light, so it might just be a matter of time till it comes on.
My Subaru had a faulty knock sensor => loss of power when accelerating
Mazda had a break in air duct => loss of power when accelerating
Punteggio 4
1 Commento:
Yeah I got the knock sensor code and p0502
da
Parti e strumenti popolari
Change the ignition coils and your problem will be fixed .Before changing coils insulate them by pvc tape
first and install them back in and if you problem decreases it will be confirmed ignition coils are bad now .so just change them .
Punteggio 2
1 Commento:
My 2005 Honda pilot jerks when I take off on freeway and after shifts fine runs good some days I have to turn off because blinking lights like the D and a ! I turn off then on and it's fine what can it be
da
The Driver ? Joke LOL
I would start with New Plugs / Oil/Air/Fuel filters. is the check engine light on ?
Punteggio 1
1 Commento:
No the check engine light isn't on.
da
my Friends Car was like that.. It would have almost NO power also.
it was the O2 Sensor that went bad and needed replacement.
weird eh?
Punteggio 0
5 Commenti:
Hi my 2000 Honda Accord is jerking when I take off from sitting still I step on the gas and it jerk pretty hard then it drive I come to a red light it stops and when I get ready to go it jerk what can this be my car has almost 100000 thanks for any info
da
What does the belt look like?
da
Mines does the same thing it starts blinking D and a ! I pull over turn it off turn back on and it runs fine after that what can it be
da
Speed sensor
da
@Lewis Johnson speed sensor
da
Had the same problem changed airfilter in Honda civic ex 56plate sorted
Punteggio 0
1 Commento:
i have honda civic 2006 d light is blinking and car is jerking when it comes to stop sing
how did you fix your car ?
da
speed pick up problem
Punteggio 0
Aggiungi la tua risposta
neha sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 245
Tutti i Tempi: 89,318
