Salta al contenuto principale
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
SSD-only iMac - future SSD additions
If I order the SSD-only iMac 27" with 256gb or 512gb, will the SSD drive be in place of the standard HDD or it will be a blade SSD connected to the PCIe port and the place for HDD will be empty? In future, I would like to add mode SSD when I run out of 256gb or 512gb or feel the need, so what kind of SSD will i need to purchase to make it work? Will it need to be SATA type or PCIe type?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes, your system will have the SSD connected to the SSD PCIe connector and the SATA connector will be vacant.
As you didn't get the HD the mounting hardware and cables will not be present. So you will need to order them when you do decide to add in an HD or second SSD via the SATA port.
Punteggio 1
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
imacsps sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,379
