Salta al contenuto principale
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Screen Backlight gone after changing LED Panel
Hi I have just replaced the LED panel on my Macbook Air 1.7ghz i5, Model MC965LL the panel is working fine as i can just make out the desktop but the backlight seems to have blown, i've put back on the old cracked screen to make sure and the backlight has def gone, could you tell me where on the logic board i can find the fuse to see if it's blown,
Please... i don't want to have to get a new logic board..
I'm willing to take the chance and and do the repair myself..
Questa è una buona domanda?
Punteggio -1
1 Commento:
What is the model number on your logic board? What are the exact specs for your MBA and any chance you can post a High-Res image of your board? I tried to mark the location of the fuse, but can not zoom in enough to do so...;-)
da
Aggiungi un commento
2 Risposte
You can try cleaning the jack where the flex cable goes in because sometime a poor contact with logic board also causes same thing. If your old screen is working fine with the back-light then your replacement screen is defiantly the faulty one.
Punteggio 0
1 Commento:
I work in a mac repair shop, so i've tried 3 screens and 2 back light displays, unfortunately i've only got one logic board, all screens are working and i would doubt 2 back light display would be faulty, so i'd imagine it would have to be the logic board..
da
Parti e strumenti popolari
Acquista tutti
I also have a MacBook Air 2013 which had a spillage. I seems the WLED driver is faulty so also no backlight. Backlight fuse is okay. Does anyone know what the part number is for the WLED driver? Part shows number on top shows 2CXH D688.
Punteggio 0
Aggiungi la tua risposta
Robert Walsh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 709
