Salta al contenuto principale
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Two SSD Drive Raid 0
Just wondering if it is possible to install 2 SSD into Mac Mini Late 2012 model and do a RAID 0 ?
I bought 2 kits from ebay and none of them able to detect the "Upper" SSD.
Is there any differences among those cables ?
Questa è una buona domanda?
Punteggio -1
2 Commenti
There does appear to be an issue with a double SSD setup refer to this question: SSD will not show up after installing
da
As I expressed to Radjin someone with the setup needs to speak to Apple as it does appear the ML installer has an issue and I suspect the EFI firmware may as well here.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Apple does have a problem with both the Mountain Lion installer as well as within the systems BIOS (EFI).
Punteggio 1
4 Commenti:
Is this an answer or a comment?
da
Answer per Apple - See other Answer for the background SSD will not show up after installing
da
After reading through all the info on the other question, I take it that the answer is "No" right now.
da
Yes, it's no for now.
da
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
Agustinus Harjono sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,355
