Salta al contenuto principale
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
How do I replace the docking connector?
Within the first 6 months I had trouble charging or transferring data, and now I need to tweak the connector continually to sustain a connection. I sent it in for servicing while warrantied and was told that there was no problem other than using the wrong (nexxtech) cable... but it just got worse.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
It seems you have to replace the note 2 charging port cable. Hope this tutorial video could help you. Good luck! http://www.youtube.com/watch?v=Opl0498DA...
Punteggio 0
1 Commento:
Sarah, careful with recommending this to often. It is included in every one of your answers. Just to make sure you are not spamming....
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Grant sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 507
