Salta al contenuto principale
The Linksys WRT54G (and variants WRT54GS, WRT54GL, and WRTSL54GS) is a Wi-Fi capable residential gateway from Linksys.
2 Domande Visualizza tutte
problem with router connection
Dear Sirs,
I have the following problem with Linksys router wtr54gl: after an unsuccessful attempt to install new software, I have no communication with the Internet and can not reset the router to factory settings.
Expect some advice.
Credit: O. Boev
Questa è una buona domanda?
Punteggio 0
1 Commento
Oghi Boev, when you say "attempt to install new software" are you referring to installing new firmware for your router? How did it fail? How did you try to do it?
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You must connect to the router via Ethernet cable for setup/upgrade. If you pooched the upgrade buy a new router... software fixes/hacks are not really our thing here.
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 1
Questa risposta era destinata originariamente a un'altra domanda.
Here's the Linksys support page for your unit WRT54GL Wireless-G Router It has all you should need to answer your questions.
Punteggio 0
Try by resetting your router and re-configure it again. Please note that your all saved setting shall gone once you have done hard reset so i would suggest if your using ADSL then get your PPPoE account setting from your ISP first and then do this.
Punteggio 0
Aggiungi la tua risposta
Oghi Boev sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 547
