sleep wake button not working
hi, the sleep/wake button on my first gen iPod touch wont work, i cant put it to sleep. so the battery dies within hours.
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Try holding the sleep and home button at the same time. Hold them until you see a white apple appear on the screen (ignore the shutdown screen and keep holding the buttons until you get to the white apple. REMEMBER HOLD TILL THE WHITE APPLE!)
When holding the buttons for a hard reboot you will see:
Screen with shutdown message and slider
black screen
White apple screen
It might just need the hard reboot.
I cant even get my iPod touch to restart by holding the sleep/wake button and the home button. when i do that nothing happens.
Not sure if holding both would work since the issue is the sleep wake button does not work anyway.
An alternative would be to go into settings > General > Auto Lock > set auto - lock to one minute.
Then when your iPod is not being used it will go to sleep after 1 minute.
Not a perfect solution but better then a dead battery.
Hope it helps.
Did u find a solution? I found that the contact ( a little spring metalic thing ) of the lock button was missing.. i've been searching the web but i dont find any replacement part..
i think you mean the iphone - the ipod touch doesn't have a lock button
i dont know how to do it but i know you have to get inside the ipod but it cracke's your screen wso i wouldnt try it
My ipod was working fine until the lock button or the top button was not working. So I put it on to auto-lock but I am gonna take it to the apple store to have them look at it.
I can help you diagnose the problem here. First take off your backplate so you can see the battery and logic board. In the top right corner you will see a gold "z" spring. take a small screwdriver and angle it on the ipod touch somewhere that is metal and touch it to the z spring. you need to make a ground, you can even just move it around a bunch trying to make a connection. If the ipod sleeps or wakes up then you just need a flex cable for the sleep button,,
if you want to advertise your business, please don't do it on here. Put your website address in you profile.
my ipod 2G has the same problem...even worse...the sleep/wake button doesn't respond and it gets in standby when it wants. the screen gets dark and i have to wait since i can wake it again. it drives me crazy!
please help
I was successful in getting my sleep/wake button to work by fiddling with the mechanical button from the inside the iPhone. With the phone charged, you can orient the screen so you can see if/when the button works or does not. There is a small metal strip on the inside of the button that I could gently push up (towards the case) or down (away from the case), and this would allow the button to work -- but only intermittently. A permanent fix was achieved by slightly de-torquing (ie, un-screwing) the 2 teensy screws on the underside of the button mechanism. I really just "relieved the pressure" on these 2 screws, I did not really unscrew them at all. This is what worked for me. Good luck. Tom
my ipod does that too, the lock button just dosent click, the volume buttons do, but not that one…
so i have to wait 1 min for it to go off
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 18,130
