Salta al contenuto principale
The PowerBook G4 Titanium Series was initially announced at Steve Jobs' keynote at MacWorld Expo in January 2001.
Limits on hard drive replacement capacity 128 gb
I have old 80 gb HD. I want to repalce with larger capacity ATA HD. I would like as much as possible 320gb Western. but I read some disclaimer that some older PowerBooks will only recognize up to 128 gb with out other commercial software? Can I partition the new HD to get around this limit? What is the other commercial software?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You can partition the drive into multiple partitions < 128GB, and it should work fine.
Punteggio 1
You'll have to do the partitioning on a newer machine and then install it in the older machine.
Punteggio 1
1 Commento:
Thanks a bunch. looks good.
da
Aggiungi la tua risposta
Doug sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,199
