Salta al contenuto principale
The TASCAM CD-01U and CD-01U Pro are professional CD players, each designed to fit into one rackspace. The professional model has balanced analog and digital outputs, while the base model has only unbalanced outputs.
problem with the cd player
the cd is slow and need a push to go in and had to take the cover off to take the cd out. Is there way to clean the cd player
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
your really don't need to clean the cd player/
the cd entry mechanism is operated by a motor and band connected to a gear. first try replacing the band that has worn out or become stretched.
since you have it open can you send me some pictures of the tray assembly?
Punteggio 0
1 Commento:
Bought a used childs radio/ CD player. The CD turns but keeps stopping. No music. CD is new. Why won't it turn fast? Then it stops & says error.
da
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Alexie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,196
