Salta al contenuto principale
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
PS VITA CRASHED during Update
I have a PS VITA PCH-1003 model. It was crashed and I get to recovery menu and selected Update option. After downloading the 2.06 update when it was installing the update it turned off suddenly. Now when I turn it on the green screen will show up and says system update please wait and then the screen become black and the system is unresponsive to buttons. The PS button is not lit up. When I connect the charger the PS button become orange and then turn back off.
Any body know how to fix this.
Your help will be appreciated.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
ok, lets see here. lets try getting it to recovery mode and see if that even works cause sounds like it might have bricked do to a corrupt system files.
press and hold “R” + Power + PS (PlayStation Button)
da
The recovery menu 4 option is disabled only one option is update
But it is already update now what I can do
da
Aggiungi un commento
2 Risposte
once in recovery select "updater system software" from here you can redo your update if this fails for any reason you can always try "rebuild database" and as a last resort "restore system"
restore system brings your vita back to the base stock firmware when you bought it and will delete everything.
Punteggio 0
1 Commento:
I cant get in to the recovery mode when I turn it on the green update screen will come and disapear and PS button also is off then it stuck at this stage cant turn it on.
da
Preparati per le riparazioni future
Acquista tutti
sounds like your power button is stuck look up how to fix non working power and play station button. pretty easy fix. theirs a you tube video of what to do.
Punteggio 0
Aggiungi la tua risposta
Nazir sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,310
