Salta al contenuto principale
Completely reset from factory settings
PC USER GIVEN 1ST APPLE PRODUCT: LOST NEEDS HELP!!
I was given an Apple Ibook G4 model number A1134 as a gift recently although I have a little problem. Okay make that more like a medium sized, problem maybe even large. Issue is I dont have the password to the former owners user account.
Apple Ibook G4
Model Number: A1134
Operating system: Mac OS X
Is there a way to reset the laptop itself from factory settings?
Or bypass the password login?
Or anything at all i can do or was this gift pointless?
SOMEONE HELP A PC USER OUT!!! IVE NEVER HAD A MAC BEFORE, IM LOST!!
Questa è una buona domanda?
Punteggio 20
6 Commenti
Power on your iBook and press the "Command" and "S" keys at the same time as the computer boots. Cease holding the two buttons when you see a black computer screen appear with white text. Type "-uw/" and press "Enter."
da
Its saying no such file or directory
da
what do i do nex
da
The command needs a slight tweak- it is “uw /“, with a space. My Book was doing the same thing until I added the space.
da
@mattues password reset
da
Mostra 1 altro commento
Aggiungi un commento
14 Risposte
Soluzione Prescelta
Here's the specs on your machine: http://everymac.com/systems/apple/ibook/...
It originally came with system X 10.4.2 (8D37)
It will take up to system 10.5.8. You may be able to get 10.4 direct from Apple for $16. Give them a call with your serial number and ask. This being to costly, try ebay. When you boot from the CD, you can go to the second screen pull down menu to Utilities > Change password, and just get rid of the old password.
Punteggio 8
3 Commenti:
just google "How to restart mac with terminal"
da
please i need software for bootable pen drive
for another pc new install for may be acer
da
david putting a question about fixing an acer onto a Q&A about an Macintosh iBook is not a good idea. Start a new question and give us specifics about what you are trying to do.
da
Parti e strumenti popolari
The gift giver should help you with the password. There are ways around the old FIRMWARE pass word if the original owner can't remember it.
If this answer was helpful please remember to mark it accepted.''
Punteggio 6
1 Commento:
Worthless.
da
after restarting press the command+s button until a black screen with white words comes up
then type:
mount -uw /
rm /var/db/ .applesetupdone
shutdown -h now
Worked great for me, hope this helps :D
Punteggio 5
6 Commenti:
tried again "no such file or diectory£
da
why wont it work ???
da
The file should be .AppleSetupDone (it is case sensitive)
Also, all this does is make it so when you power up it will go through the system setup again. All existing users are still there; all apps are still there. The only thing you are doing is renaming the computer and creating a new user.
da
It keeps saying password. . I can't type anything. Please help
da
the reason it dont work its becuz is not command+s, its option+command+f+o, and then the other steps,itl work perfect.
da
This will allow you to gain access to your macbook
Step 1 of 6
Step 2 of 6
Type "-uw/" and press "Enter." This will allow you to make changes to the hard drive.
Step 3 of 6
Type "Systemstarter" and press "Enter" to run "NetInfo" (this allows you to make changes to the user accounts on your iBook). A vast amount of messages will begin appearing on your screen. When you see the message "System started" appear, hit "Enter" to display a command prompt.
Step 4 of 6
Type "niutil -list . /users" and press "Enter." A list of the user accounts on your iBook will now appear.
Step 5 of 6
Find the name of the account you are wanting to use (most likely the administrator account) and type "passwd user --" (replace "user" with the name of the account you will be using). The command prompt will tell you twice that you are changing the password for the account you chose to change; therefore, enter the name of the account twice (ensure you are typing the name of the account correctly and the "Caps Lock" is off as you will not see what you are typing).
Step 6 of 6
Type "reboot" and press "Enter" to restart your iBook. The account you want to unlock will now be completely unlocked, allowing you to freely log into the account without any trouble whatsoever.
Punteggio 3
6 Commenti:
Not working
da
I entered /sbin/fsck -fy and then systemstarter, screen says "could not create IPC bootstrap port. Then entered niutil -list . /users and nothing happens. Any suggestions?
Steve
da
Just had an epiphany and the information all came to me! Thanks God
da
tried this many times message keeps repeating "No such file or directory" what next please?
da
If you are still around, sdreamer9 - PLEASE tell us what the epiphany was. I am struggling with these same problems and don't have a CLUE what to do. Thanks.
da
''Oh how wrong you are, !@#$ and I wish you were correct. I just followed every thing you layed out and i rebooted back to the same Darwin from !@#$ screen.
Why is what I'm writting have the added swearing ( !&%?)
Punteggio 1
My keyboard is broken and I use the on screen keyboard is there a way to do this without typing on using the on screen keyboard?
Punteggio 1
Does anyone know how to enable cookies on an iBook g4?
Thanks
Punteggio 1
no black screen appeared even i hold it..its loading to login windows again and again
Punteggio 1
1 Commento:
.....It's loading Windows.....?!
da
Is there a way to change the serial number of a mac when they replace the logic bd and now it has a new serial number?
Punteggio 0
After i updated the latest version of itunes on ibook64 the screen turn black and i cant open it what should i do.
Punteggio 0
is it
uw/
or
-uw/
? neither works anyway, after i found out what “command key” was…. is there a way to completely clean hard drive to be like a new computer? i have all the discs.
Punteggio 0
actully im with rachel….DOES ANYONE HAVE A LEGIT AND SOLID WAY TO RESTORE iBOOK g4 TO FACTORY….I have password i just dont know how because i dont mess with Apple for this reason right here
Punteggio 0
1 Commento:
Please read my old answer above. i'd take it to 10.5.8 using a retail install disk available on eBay.
da
i need help because
mount -uw / worked but
rm /var/db/ .AppleSetupDone didnt this time
somebody help me fix that because i want to factory reset
Punteggio 0
hi i have bought second laptop ibook g4 and same problem he have name and password i click command and s but no screen black coming what i do
Punteggio 0
Aggiungi la tua risposta
Rachel Ross sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 63
Tutti i Tempi: 101,261
