Salta al contenuto principale
L'HTC Droid Incredible è uno smartphone Android esclusivo per Verizon, rilasciato nell'aprile 2010.
How to fix water damage
i want to know how to solve the problem of fixing an incredible that is water damaged. do i get a new logic board.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione prescelta
walt, the very first thing I would do, is to clean the complete phone, disassembled of course, with high grade isopropyl alcohol. Use this guide to work on your phone, and check on here about general cleaning. This great guide shows how to clean an iPhone, but all the points are still pertinent to your phone as well. Replace the battery after cleaning and see what you get. Hope this helps, good luck
Immagine iPhone
Guida
Riparazione danno da liquidi iPhone
Difficoltà:
Difficile
1 - 2 hours
Immagine HTC Droid Incredible scheda logica
Guida
Riparazione scheda logica HTC Droid Incredible
Difficoltà:
Moderato
30 minutes
Punteggio 1
First of all, I would recommend you to disassemble the entire phone and one by one use a heat gun to apply warm heat for each part so that any damaged parts would dissolve any part of liquid left. It will reform the parts back to its original state within matter of minutes after heat is applied.
Punteggio 0
1 Commento:
Saf Sajid, what about corrosion?
da
will this work on my htc one s? I dropped it in water and now the sound dosent work,everything else works fine.
Thanks Ill wait for your reply
Punteggio 0
1 Commento:
@ stella, No reason why it shouldn't. I definitely suggest for you to start with that. If nothing else, it will provide you with a known good starting point.
da
Aggiungi la tua risposta
walt sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 9
Tutti i Tempi: 2,855
