Salta al contenuto principale
iFixit utilizza i cookie per migliorare le funzionalità del sito, analizzare il traffico e personalizzare gli annunci. Utilizzando il nostro sito, accetti l'uso dei cookie e l<link>Informativa sulla privacy</link>.
Released by Nokia in May 2009, the Nokia 6303 is designed mainly for voice calls, texting, and music playback.
resetting security code how
My keypad is locked with security code. I changed the security code. Now I can't open it. Either I forgot what code I entered or I pressed the wrong numbers and I didn't know. Now I can't unlock my phone. What can I do to solve this?
Questa è una buona domanda?
Punteggio 29
4 Commenti
Tengo un telefono que me enviaron desde inglaterra y vivo en colombia como hago para el codigo de seguridad
da
nokia6303 secruty code
da
I keep receiving phone number. 6303036998032 ? my phone ia a Samsung ?
What is going on?
da
unlock my moile nokia 6303i
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
What's your Mobile model?
Try default codes like 12345,00000.If your mobile is Nokia or Alcatel you easily reset your mobile by using Master Reset code.You can get the code from Unlock-Free.com at free of cost.Here they will generate you reset code within a minute by specifying your mobile model no and IMEI.
Note:They will provide reset codes for some basic Alcatel and Nokia mobile models only.
Punteggio 2
3 Commenti:
Thank you you umblocked my password Im so stupid
da
cant find nokia 6303ci !
da
Hi security code for Nokia ta-1402 8 digits
da
Parti e strumenti popolari
Kae, follow these instructions Hope this helps, good luck.
Punteggio 1
3 Commenti:
Dead link. Was going to accept it, letting you know. I also got a redirect alert from AdGuard in Chrome, now the site will not load in Safari OR Chrome. Normally I'd try and find a working reference but with 2G being doomed globally I'm just going to "solve" this one by accepting @braksa's answer.
Likely blocked by the Mac AdGuard app. Not your fault the ownership changed, but I'm letting you know.
da
@nick 🤣you know it does not matter as long as something worked for the OP. It’s not about accepting but about getting in solved. Best answer is always the right answer 👍
da
@oldturkey03 it either redirects to a dead page or very suspicious links.
da
i forget my nokia 6303ci password ,how to open it?
Punteggio 1
Aggiungi la tua risposta
Kae sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 88
Tutti i Tempi: 24,378
