Salta al contenuto principale
iRobot Roomba Battery Replacement
Cosa ti serve
  1. iRobot Roomba Battery Replacement, Loosen the edge brush screw: passo 1, immagine 1 di 1
    • Make sure your Roomba is turned off and flip it over to access its underside.
    • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
    • This screw is a captive screw and therefore not removable.
    Chiedi a FixBot
    Aggiungi Commento
  2. iRobot Roomba Battery Replacement, Remove the edge brush: passo 2, immagine 1 di 2 iRobot Roomba Battery Replacement, Remove the edge brush: passo 2, immagine 2 di 2
    • Use your fingers to gather all three brush arms and grab them simultaneously.
    • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
    Chiedi a FixBot
    Aggiungi Commento
  3. iRobot Roomba Battery Replacement, Loosen the bottom screws: passo 3, immagine 1 di 2 iRobot Roomba Battery Replacement, Loosen the bottom screws: passo 3, immagine 2 di 2
    • Use a Phillips screwdriver to loosen the five captive screws that hold the bottom plate in place.
    • Those screws are captive screws and therefore not removable.
    Chiedi a FixBot
    Aggiungi Commento
  4. iRobot Roomba Battery Replacement, Remove the bottom plate: passo 4, immagine 1 di 3 iRobot Roomba Battery Replacement, Remove the bottom plate: passo 4, immagine 2 di 3 iRobot Roomba Battery Replacement, Remove the bottom plate: passo 4, immagine 3 di 3
    • Grab the bottom plate with your hand and remove it by lifting it straight up to reveal the battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. iRobot Roomba Battery Replacement, Unlatch and remove the battery: passo 5, immagine 1 di 3 iRobot Roomba Battery Replacement, Unlatch and remove the battery: passo 5, immagine 2 di 3 iRobot Roomba Battery Replacement, Unlatch and remove the battery: passo 5, immagine 3 di 3
    • Use your finger to bend the plastic clip and unlatch the battery.
    • Grab the battery with your hand and lift it straight up from inside its recess to remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Tobias Isakeit
Membro da: 03/31/14
133.802 Reputazione
189 guide realizzate
Tobias Isakeit - Repairability Engineer Membro di Tobias Isakeit - Repairability Engineer
Business
Membro di 1
1.145 guide realizzate
1Commento della guida
J'ai changé la batterie compatible avec mon roomba mdle. 785, ça fonctionnait bien, mais au moment de la recharge elle ne reconnaît plus la batterie
Que faire
Lemon' attitude - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 39
Ultimi 30 giorni: 225
Tutti i Tempi: 9,137
