Salta al contenuto principale
iPhone 16 Pro Logic Board Replacement
Cosa ti serve
  1. iPhone 16 Pro Logic Board Replacement, Prepare the phone for disassembly: passo 1, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Prepare the phone for disassembly: passo 1, immagine 2 di 2
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
  2. iPhone 16 Pro Logic Board Replacement, Tape over any cracks: passo 2, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Tape over any cracks: passo 2, immagine 2 di 2
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Logic Board Replacement, Mark your opening picks: passo 3, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement, Mark your opening picks: passo 3, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement, Mark your opening picks: passo 3, immagine 3 di 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro Logic Board Replacement, Remove the pentalobe screws: passo 4, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Remove the pentalobe screws: passo 4, immagine 2 di 2
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro Logic Board Replacement, Heat the bottom edge: passo 5, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Heat the bottom edge: passo 5, immagine 2 di 2
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 16 Pro Logic Board Replacement, Insert an opening pick: passo 6, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement, Insert an opening pick: passo 6, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement, Insert an opening pick: passo 6, immagine 3 di 3
    • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro Logic Board Replacement, Back glass information: passo 7, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Back glass information: passo 7, immagine 2 di 2
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    • If you damage the spring contacts, gently bend them back with a spudger or opening pick so they align with their gold contact pads on the back glass.
  8. iPhone 16 Pro Logic Board Replacement, Separate the bottom edge adhesive: passo 8, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement, Separate the bottom edge adhesive: passo 8, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement, Separate the bottom edge adhesive: passo 8, immagine 3 di 3
    • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contact.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro Logic Board Replacement, Heat the right edge: passo 9, immagine 1 di 1
    • Heat the right edge of the back glass until it's hot to the touch.
  10. iPhone 16 Pro Logic Board Replacement, Separate the bottom right corner adhesive: passo 10, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Separate the bottom right corner adhesive: passo 10, immagine 2 di 2
    • Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 16 Pro Logic Board Replacement, Heat the left edge: passo 11, immagine 1 di 1
    • Heat the left edge of the back glass until it's hot to the touch.
  12. iPhone 16 Pro Logic Board Replacement, Separate the left edge adhesive: passo 12, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Separate the left edge adhesive: passo 12, immagine 2 di 2
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  13. iPhone 16 Pro Logic Board Replacement, Heat the top edge: passo 13, immagine 1 di 1
    • Heat the top edge of the back glass, including the area around the volume buttons, until it's hot to the touch.
  14. iPhone 16 Pro Logic Board Replacement, Separate the top edge adhesive: passo 14, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Separate the top edge adhesive: passo 14, immagine 2 di 2
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
    • You'll hear and feel clicks as the top two clips release.
  15. iPhone 16 Pro Logic Board Replacement, Swing open the back glass: passo 15, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Swing open the back glass: passo 15, immagine 2 di 2
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
    • Gently swing open the back glass towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    • Remove the opening picks.
    • Consider using polyimide tape to protect the rear camera lenses while you're working inside the phone. Don't push against the lenses to avoid damaging the delicate stabilizers.
  16. iPhone 16 Pro Logic Board Replacement, Disconnect the battery: passo 16, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Disconnect the battery: passo 16, immagine 2 di 2
    • Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
    • Two 1.2 mm‑long screws
    • One 1.0 mm‑long screw
  17. iPhone 16 Pro Logic Board Replacement: passo 17, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement: passo 17, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement: passo 17, immagine 3 di 3
    • Use tweezers or your fingers to pick up and remove the lower connector cover.
  18. iPhone 16 Pro Logic Board Replacement: passo 18, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement: passo 18, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement: passo 18, immagine 3 di 3
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  19. iPhone 16 Pro Logic Board Replacement, Disconnect the back glass: passo 19, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Disconnect the back glass: passo 19, immagine 2 di 2
    • Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
    • Two 1.0 mm‑long screws
    • One 1.2 mm‑long screw
    • One 1.6 mm‑long screw
  20. iPhone 16 Pro Logic Board Replacement: passo 20, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement: passo 20, immagine 2 di 2
    • Use tweezers or your fingers to pick up and remove the upper connector cover.
  21. iPhone 16 Pro Logic Board Replacement: passo 21, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement: passo 21, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the back glass press connector.
  22. iPhone 16 Pro Logic Board Replacement, Remove the back glass: passo 22, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Remove the back glass: passo 22, immagine 2 di 2
    • Lift the back glass off the frame and remove it.
  23. iPhone 16 Pro Logic Board Replacement, Disconnect the earpiece speaker: passo 23, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement, Disconnect the earpiece speaker: passo 23, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement, Disconnect the earpiece speaker: passo 23, immagine 3 di 3
    • The 5G mmWave antenna is only in United States and Puerto Rico iPhone 16 Pros (model A3083). For all other models, skip the next four steps.
    • Use the point of a spudger to pry up and disconnect the earpiece speaker and 5G mmWave antenna press connectors, located on the top right corner of the logic board.
  24. iPhone 16 Pro Logic Board Replacement, Remove the earpiece speaker: passo 24, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Remove the earpiece speaker: passo 24, immagine 2 di 2
    • Use a Phillips screwdriver to remove the six screws securing the earpiece speaker:
    • Three 1.2 mm‑long screws
    • Two 1.8 mm‑long screws
    • One 1.7 mm‑long screw
  25. iPhone 16 Pro Logic Board Replacement: passo 25, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement: passo 25, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement: passo 25, immagine 3 di 3
    • Insert the point of a spudger in the bottom-right corner of the earpiece speaker and pry it up to remove it.
    • You may feel some resistance near the top edge, where the speaker gasket seals against the frame. Pull the speaker out gently to release the seal.
  26. iPhone 16 Pro Logic Board Replacement, Disconnect the logic board: passo 26, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Disconnect the logic board: passo 26, immagine 2 di 2
    • Use a spudger to pry up and disconnect the press connectors from the top of the logic board:
    • Seven silver connectors
    • Three black connectors
    • One of the black connectors is under the two silver connectors on the left edge of the board.
  27. iPhone 16 Pro Logic Board Replacement, Remove the screws: passo 27, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Remove the screws: passo 27, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Standoff Screwdriver for iPhones
    $5.49
    • Standoff screws are best removed using a dedicated standoff screwdriver or driver bit. In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • Use a standoff screwdriver to remove the four screws securing the logic board:
    • Two 4.5 mm‑long screws
    • One 3.4 mm‑long screw
    • One 4.2 mm‑long screw
  28. iPhone 16 Pro Logic Board Replacement, Screen connector information: passo 28, immagine 1 di 1
    • This image shows the display connector underneath the logic board with the board removed. The next two steps show how to disconnect this connector from the logic board.
  29. iPhone 16 Pro Logic Board Replacement, Remove the logic board: passo 29, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Remove the logic board: passo 29, immagine 2 di 2
    • If the iPhone has a SIM card tray, eject it before you proceed.
    • USA model iPhones (A3084) don't have a SIM card tray.
    • Make sure all the connectors are disconnected from the top of the logic board before proceeding.
    • Insert the flat edge of an opening pick between the battery and the logic board. Hold the pick in place with your fingers.
  30. iPhone 16 Pro Logic Board Replacement: passo 30, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement: passo 30, immagine 2 di 2
    • Don't remove the logic board yet. There's still a cable connected to the bottom side.
    • Insert the flat end of a spudger underneath the right edge of the logic board.
    • Gently pry with the spudger and opening pick to lift the logic board and disconnect the screen connector.
  31. iPhone 16 Pro Logic Board Replacement: passo 31, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement: passo 31, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement: passo 31, immagine 3 di 3
    • Pick up the bottom edge of the logic board, flip it up towards the top of the phone, and hold it steady vertically.
    • Use the point of a spudger to pry up and disconnect the front sensor connector from the underside of the logic board.
  32. iPhone 16 Pro Logic Board Replacement: passo 32, immagine 1 di 1
    • Remove the logic board.
  33. iPhone 16 Pro Logic Board Replacement, Connect the front sensor cable: passo 33, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Connect the front sensor cable: passo 33, immagine 2 di 2
    • Hold the logic board above the phone so the socket on the underside of the board is close to the front sensor cable.
    • Use your finger or a spudger to press the front sensor cable connector into its socket on the logic board until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  34. iPhone 16 Pro Logic Board Replacement, Lay the logic board in place: passo 34, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement, Lay the logic board in place: passo 34, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement, Lay the logic board in place: passo 34, immagine 3 di 3
    • Use your fingers or a spudger to gently hold all the loose press connectors out of the way so you can lay the logic board in place.
    • Lay the logic board in its recess.
  35. iPhone 16 Pro Logic Board Replacement, Install the logic board: passo 35, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Install the logic board: passo 35, immagine 2 di 2
    • You can't directly connect the display connector to the bottom of the logic board without removing the screen, but you might successfully connect it by screwing the logic board in place. Be sure to test your iPhone later in this guide.
    • If it fails, work back to this step and try again or follow the screen replacement guide to connect it manually.
    • Make sure the logic board rests in place against its screw posts. The posts will properly align the board to the display connector underneath it.
  36. iPhone 16 Pro Logic Board Replacement: passo 36, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement: passo 36, immagine 2 di 2
    • Use a standoff screwdriver to install the four screws securing the logic board:
  37. iPhone 16 Pro Logic Board Replacement: passo 37, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement: passo 37, immagine 2 di 2
    • To connect press connectors like these, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Use your finger or a spudger to connect the press connectors to the top of the logic board:
    • One of the black connectors is under the two silver connectors on the left edge of the board, and needs to be connected first.
    • Don't connect the battery press connector, labeled with a "+" and "-".
  38. iPhone 16 Pro Logic Board Replacement, Install the earpiece speaker: passo 38, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement, Install the earpiece speaker: passo 38, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement, Install the earpiece speaker: passo 38, immagine 3 di 3
    • Insert the top edge of the earpiece speaker into its cutout at a downward angle before pressing it flat to the frame.
    • You may have to lift the front camera assembly just enough to get the earpiece speaker in its cutout. Route the antenna and earpiece speaker cables to the right of the front camera cables. Press the front camera into its cutout, then push its cables flush with the rear cameras.
  39. iPhone 16 Pro Logic Board Replacement: passo 39, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement: passo 39, immagine 2 di 2
    • Use a Phillips screwdriver to install the six screws securing the earpiece speaker:
  40. iPhone 16 Pro Logic Board Replacement, Connect the earpiece speaker: passo 40, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement, Connect the earpiece speaker: passo 40, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement, Connect the earpiece speaker: passo 40, immagine 3 di 3
  41. iPhone 16 Pro Logic Board Replacement, Remove the leftover adhesive: passo 41, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement, Remove the leftover adhesive: passo 41, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement, Remove the leftover adhesive: passo 41, immagine 3 di 3
    • Work around the fragile grounding clips as you're cleaning the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
    • Use a spudger to scrape the adhesive residue off of the frame.
    • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
  42. iPhone 16 Pro Logic Board Replacement, Clean the back glass: passo 42, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Clean the back glass: passo 42, immagine 2 di 2
    Microfiber Cleaning Cloths
    $3.99
    • If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
  43. iPhone 16 Pro Logic Board Replacement, Clean the frame: passo 43, immagine 1 di 1
    • Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
  44. iPhone 16 Pro Logic Board Replacement, Apply the replacement adhesive: passo 44, immagine 1 di 1
    • Lay the adhesive sheet over the frame to determine its proper orientation.
    • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
  45. iPhone 16 Pro Logic Board Replacement: passo 45, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement: passo 45, immagine 2 di 2
    • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
    • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
    • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
  46. iPhone 16 Pro Logic Board Replacement: passo 46, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement: passo 46, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement: passo 46, immagine 3 di 3
    • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
  47. iPhone 16 Pro Logic Board Replacement: passo 47, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement: passo 47, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement: passo 47, immagine 3 di 3
    • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
    • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
    • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
    • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
    • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
  48. iPhone 16 Pro Logic Board Replacement: passo 48, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement: passo 48, immagine 2 di 2
    • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
    • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Don't press too hard, or you'll stretch and deform the adhesive.
  49. iPhone 16 Pro Logic Board Replacement: passo 49, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement: passo 49, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement: passo 49, immagine 3 di 3
    • Use a spudger or your fingers to lift the pull tab connected to the large front liner. The pull tab is often in a corner of the liner.
    • Use the pull tab to peel off the large front liner from the adhesive.
    • At this point, you may still have a liner covering the perimeter, which prevents the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
  50. iPhone 16 Pro Logic Board Replacement, Connect the back glass: passo 50, immagine 1 di 1
    • Prop up the back glass along the right edge of your iPhone.
  51. iPhone 16 Pro Logic Board Replacement: passo 51, immagine 1 di 1
    • Use your finger or the flat end of a spudger to press and connect the back glass connector onto the logic board.
  52. iPhone 16 Pro Logic Board Replacement, Connect the battery: passo 52, immagine 1 di 1
    • Use your finger or a spudger to press and connect the battery press connector onto the logic board.
    • This is a good point to test your repair before sealing up your iPhone. Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
    • If your iPhone doesn't turn on, connect it to a power source and try again.
    • If you've replaced the logic board and the screen fails to turn on, you'll need to follow the screen guide to manually connect the display connector.
  53. iPhone 16 Pro Logic Board Replacement, Install the connector covers: passo 53, immagine 1 di 1
    • Align the back glass connector cover by its screw holes and lay it in place.
  54. iPhone 16 Pro Logic Board Replacement: passo 54, immagine 1 di 1
    • Use a tri-point Y000 driver to install the four screws securing the back glass connector cover:
    • Two 1.3 mm‑long screws
  55. iPhone 16 Pro Logic Board Replacement: passo 55, immagine 1 di 1
    • Align the battery connector cover by its screw holes and lay it in place.
  56. iPhone 16 Pro Logic Board Replacement: passo 56, immagine 1 di 1
    • Use a tri-point Y000 driver to install the three screws securing the battery connector cover:
  57. iPhone 16 Pro Logic Board Replacement, Remove the final adhesive liners: passo 57, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Remove the final adhesive liners: passo 57, immagine 2 di 2
    • Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
    • As you remove the liners, make sure nothing touches the exposed adhesive.
    • Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
  58. iPhone 16 Pro Logic Board Replacement, Install the back glass: passo 58, immagine 1 di 3 iPhone 16 Pro Logic Board Replacement, Install the back glass: passo 58, immagine 2 di 3 iPhone 16 Pro Logic Board Replacement, Install the back glass: passo 58, immagine 3 di 3
    • Lower the back glass onto the frame, beginning with the top edge.
    • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
    • Press along the edges of the iPhone until the back glass sits flush against the frame.
  59. iPhone 16 Pro Logic Board Replacement, Apply heat to the perimeter: passo 59, immagine 1 di 1
    • Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
    • The heat softens the adhesive and helps create a better bond.
  60. iPhone 16 Pro Logic Board Replacement, Apply pressure to the perimeter: passo 60, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Apply pressure to the perimeter: passo 60, immagine 2 di 2
    • Use your fingers to firmly squeeze around the perimeter of the iPhone.
  61. iPhone 16 Pro Logic Board Replacement: passo 61, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement: passo 61, immagine 2 di 2
    • Place your iPhone screen-side down on a clean, flat work surface.
    • Lay a strip of tape around the perimeter of the back glass to protect the finish.
    • Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
    • Alternatively, you can use vise clamps around the perimeter of your device to set the new adhesive.
  62. iPhone 16 Pro Logic Board Replacement: passo 62, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement: passo 62, immagine 2 di 2
    • Place 3-4 heavy books squarely on top of your iPhone.
    • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
    • Leave the books in place for about 30 minutes.
    • The pressure will help activate the adhesive.
  63. iPhone 16 Pro Logic Board Replacement, Install the pentalobe screws: passo 63, immagine 1 di 2 iPhone 16 Pro Logic Board Replacement, Install the pentalobe screws: passo 63, immagine 2 di 2
    • Use a P2 pentalobe screwdriver to install the two 7.4 mm‑long screws on either side of the USB-C port.
Conclusione
After your repair, calibrate genuine replacement parts using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
Nick Schultz
Membro da: 03/24/24
53.684 Reputazione
305 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
25.687 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 20
Ultimi 7 Giorni: 89
Ultimi 30 Giorni: 435
Tutti i Tempi: 5,146
