Salta al contenuto principale
iPhone 15 Logic Board Replacement
Cosa ti serve
  1. iPhone 15 Logic Board Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 2 iPhone 15 Logic Board Replacement, Prepare your phone for disassembly: passo 1, immagine 2 di 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. iPhone 15 Logic Board Replacement, Tape over any cracks: passo 2, immagine 1 di 2 iPhone 15 Logic Board Replacement, Tape over any cracks: passo 2, immagine 2 di 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Chiedi a FixBot
    Aggiungi Commento
  3. iPhone 15 Logic Board Replacement, Mark your opening picks: passo 3, immagine 1 di 3 iPhone 15 Logic Board Replacement, Mark your opening picks: passo 3, immagine 2 di 3 iPhone 15 Logic Board Replacement, Mark your opening picks: passo 3, immagine 3 di 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Chiedi a FixBot
    Aggiungi Commento
  4. iPhone 15 Logic Board Replacement, Remove the pentalobe screws: passo 4, immagine 1 di 2 iPhone 15 Logic Board Replacement, Remove the pentalobe screws: passo 4, immagine 2 di 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
    Chiedi a FixBot
    Aggiungi Commento
  5. iPhone 15 Logic Board Replacement, Heat the bottom edge: passo 5, immagine 1 di 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Chiedi a FixBot
    Aggiungi Commento
  6. iPhone 15 Logic Board Replacement, Insert an opening pick: passo 6, immagine 1 di 3 iPhone 15 Logic Board Replacement, Insert an opening pick: passo 6, immagine 2 di 3 iPhone 15 Logic Board Replacement, Insert an opening pick: passo 6, immagine 3 di 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    Chiedi a FixBot
    Aggiungi Commento
  7. iPhone 15 Logic Board Replacement, Screen information: passo 7, immagine 1 di 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone, one just above the mute switch, and the other about halfway between the volume down button and the bottom of the phone.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    Chiedi a FixBot
    Aggiungi Commento
  8. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: passo 8, immagine 1 di 3 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: passo 8, immagine 2 di 3 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: passo 8, immagine 3 di 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Chiedi a FixBot
    Aggiungi Commento
  9. iPhone 15 Logic Board Replacement, Heat the right edge: passo 9, immagine 1 di 1
    • Heat the right edge of the screen until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  10. iPhone 15 Logic Board Replacement, Position the opening pick: passo 10, immagine 1 di 3 iPhone 15 Logic Board Replacement, Position the opening pick: passo 10, immagine 2 di 3 iPhone 15 Logic Board Replacement, Position the opening pick: passo 10, immagine 3 di 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
    Chiedi a FixBot
    Aggiungi Commento
  11. iPhone 15 Logic Board Replacement, Release the right clip: passo 11, immagine 1 di 3 iPhone 15 Logic Board Replacement, Release the right clip: passo 11, immagine 2 di 3 iPhone 15 Logic Board Replacement, Release the right clip: passo 11, immagine 3 di 3
    • Hold the pick with one hand and twist it to increase the gap between the screen and the frame and release the right clip.
    • Insert a second opening pick to the right of the first one.
    Chiedi a FixBot
    Aggiungi Commento
  12. iPhone 15 Logic Board Replacement, Separate the right edge adhesive: passo 12, immagine 1 di 3 iPhone 15 Logic Board Replacement, Separate the right edge adhesive: passo 12, immagine 2 di 3 iPhone 15 Logic Board Replacement, Separate the right edge adhesive: passo 12, immagine 3 di 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  13. iPhone 15 Logic Board Replacement, Heat the top edge: passo 13, immagine 1 di 1
    • Heat the top edge of the screen until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  14. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: passo 14, immagine 1 di 3 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: passo 14, immagine 2 di 3 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: passo 14, immagine 3 di 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Insert a third opening pick in the top right corner, just above the previous pick.
    • Slide your pick around the top right corner and along the top edge until you feel it stop against the top left screen clip.
    Chiedi a FixBot
    Aggiungi Commento
  15. iPhone 15 Logic Board Replacement, Release the top edge clips: passo 15, immagine 1 di 3 iPhone 15 Logic Board Replacement, Release the top edge clips: passo 15, immagine 2 di 3 iPhone 15 Logic Board Replacement, Release the top edge clips: passo 15, immagine 3 di 3
    • Rotate your pick so its flat edge is under the screen.
    • Twist your pick to release the top left screen clip.
    • Slide your pick to the top left corner.
    Chiedi a FixBot
    Aggiungi Commento
  16. iPhone 15 Logic Board Replacement, Heat the left edge: passo 16, immagine 1 di 1
    • Heat the left edge of the screen until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  17. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: passo 17, immagine 1 di 3 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: passo 17, immagine 2 di 3 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: passo 17, immagine 3 di 3
    • Don't insert your pick deeper than 3 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Slide your pick around the top left corner of the screen and along the left edge to release the clips and separate the adhesive securing it.
    Chiedi a FixBot
    Aggiungi Commento
  18. iPhone 15 Logic Board Replacement, Swing open the screen: passo 18, immagine 1 di 3 iPhone 15 Logic Board Replacement, Swing open the screen: passo 18, immagine 2 di 3 iPhone 15 Logic Board Replacement, Swing open the screen: passo 18, immagine 3 di 3
    • Gently swing open the screen over the left edge of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    Chiedi a FixBot
    Aggiungi Commento
  19. iPhone 15 Logic Board Replacement, Unfasten the front sensor connector cover: passo 19, immagine 1 di 1
    • Use a tri-point Y000 driver to remove the 0.9 mm-long screw securing the front sensor connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  20. iPhone 15 Logic Board Replacement, Remove the cover: passo 20, immagine 1 di 3 iPhone 15 Logic Board Replacement, Remove the cover: passo 20, immagine 2 di 3 iPhone 15 Logic Board Replacement, Remove the cover: passo 20, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Use tweezers to lift the cover to a 90-degree angle.
    • Unhook the cover from its slot in the logic board.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  21. iPhone 15 Logic Board Replacement, Disconnect the front sensor: passo 21, immagine 1 di 2 iPhone 15 Logic Board Replacement, Disconnect the front sensor: passo 21, immagine 2 di 2
    • Use the tip of an opening pick to pry up and disconnect the front sensor press connector.
    Chiedi a FixBot
    Aggiungi Commento
  22. iPhone 15 Logic Board Replacement, Unfasten the screen connector cover: passo 22, immagine 1 di 1
    • Use your tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  23. iPhone 15 Logic Board Replacement, Remove the cover: passo 23, immagine 1 di 2 iPhone 15 Logic Board Replacement, Remove the cover: passo 23, immagine 2 di 2
    • Use tweezers to lift the cover and unlatch it from its hook on the logic board.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  24. iPhone 15 Logic Board Replacement, Disconnect the screen: passo 24, immagine 1 di 2 iPhone 15 Logic Board Replacement, Disconnect the screen: passo 24, immagine 2 di 2
    • Use the tip of an opening pick to pry up and disconnect the screen press connector.
    Chiedi a FixBot
    Aggiungi Commento
  25. iPhone 15 Logic Board Replacement, Remove the screen: passo 25, immagine 1 di 1
    • Remove the screen.
    Chiedi a FixBot
    Aggiungi Commento
  26. iPhone 15 Logic Board Replacement, Flip your iPhone over: passo 26, immagine 1 di 1
    Microfiber Cleaning Cloths
    $3.99
    • Flip your phone over and lay it on a soft surface, such as a microfiber cloth, to protect its internals as you work.
    Chiedi a FixBot
    Aggiungi Commento
  27. iPhone 15 Logic Board Replacement, Heat the bottom edge: passo 27, immagine 1 di 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  28. iPhone 15 Logic Board Replacement, Insert an opening pick: passo 28, immagine 1 di 3 iPhone 15 Logic Board Replacement, Insert an opening pick: passo 28, immagine 2 di 3 iPhone 15 Logic Board Replacement, Insert an opening pick: passo 28, immagine 3 di 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    Chiedi a FixBot
    Aggiungi Commento
  29. iPhone 15 Logic Board Replacement, Back glass information: passo 29, immagine 1 di 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    Chiedi a FixBot
    Aggiungi Commento
  30. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: passo 30, immagine 1 di 3 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: passo 30, immagine 2 di 3 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: passo 30, immagine 3 di 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    Chiedi a FixBot
    Aggiungi Commento
  31. iPhone 15 Logic Board Replacement, Heat the right edge: passo 31, immagine 1 di 1
    • Heat the right edge of the back glass until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  32. iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: passo 32, immagine 1 di 3 iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: passo 32, immagine 2 di 3 iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: passo 32, immagine 3 di 3
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
    • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  33. iPhone 15 Logic Board Replacement, Heat the left edge: passo 33, immagine 1 di 1
    • Heat the left edge of the back glass until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  34. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: passo 34, immagine 1 di 3 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: passo 34, immagine 2 di 3 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: passo 34, immagine 3 di 3
    • Along the left edge, don't insert your pick deeper than 5 mm.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  35. iPhone 15 Logic Board Replacement, Heat the top edge: passo 35, immagine 1 di 1
    • Heat the top edge of the back glass until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  36. iPhone 15 Logic Board Replacement, Separate the top edge adhesive: passo 36, immagine 1 di 3 iPhone 15 Logic Board Replacement, Separate the top edge adhesive: passo 36, immagine 2 di 3 iPhone 15 Logic Board Replacement, Separate the top edge adhesive: passo 36, immagine 3 di 3
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  37. iPhone 15 Logic Board Replacement, Heat the top right corner: passo 37, immagine 1 di 1
    • Heat the top right corner of the back glass until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  38. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: passo 38, immagine 1 di 3 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: passo 38, immagine 2 di 3 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: passo 38, immagine 3 di 3
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  39. iPhone 15 Logic Board Replacement, Open the back glass: passo 39, immagine 1 di 3 iPhone 15 Logic Board Replacement, Open the back glass: passo 39, immagine 2 di 3 iPhone 15 Logic Board Replacement, Open the back glass: passo 39, immagine 3 di 3
    • Gently lift and swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
    Chiedi a FixBot
    Aggiungi Commento
  40. iPhone 15 Logic Board Replacement, Unfasten the lower connector cover: passo 40, immagine 1 di 1
    FixMat
    $31.41
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  41. iPhone 15 Logic Board Replacement, Remove the lower connector cover: passo 41, immagine 1 di 3 iPhone 15 Logic Board Replacement, Remove the lower connector cover: passo 41, immagine 2 di 3 iPhone 15 Logic Board Replacement, Remove the lower connector cover: passo 41, immagine 3 di 3
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  42. iPhone 15 Logic Board Replacement, Disconnect the battery: passo 42, immagine 1 di 3 iPhone 15 Logic Board Replacement, Disconnect the battery: passo 42, immagine 2 di 3 iPhone 15 Logic Board Replacement, Disconnect the battery: passo 42, immagine 3 di 3
    • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
    • A plus and minus sign is printed on the head of this connector.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  43. iPhone 15 Logic Board Replacement, Unfasten the middle connector cover: passo 43, immagine 1 di 2 iPhone 15 Logic Board Replacement, Unfasten the middle connector cover: passo 43, immagine 2 di 2
    • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  44. iPhone 15 Logic Board Replacement, Remove the cover: passo 44, immagine 1 di 3 iPhone 15 Logic Board Replacement, Remove the cover: passo 44, immagine 2 di 3 iPhone 15 Logic Board Replacement, Remove the cover: passo 44, immagine 3 di 3
    • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  45. iPhone 15 Logic Board Replacement, Disconnect the wireless charging coil: passo 45, immagine 1 di 2 iPhone 15 Logic Board Replacement, Disconnect the wireless charging coil: passo 45, immagine 2 di 2
    • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
    Chiedi a FixBot
    Aggiungi Commento
  46. iPhone 15 Logic Board Replacement, Remove the back glass: passo 46, immagine 1 di 1
    • Remove the back glass.
    Chiedi a FixBot
    Aggiungi Commento
  47. iPhone 15 Logic Board Replacement, Remove the upper connector cover: passo 47, immagine 1 di 3 iPhone 15 Logic Board Replacement, Remove the upper connector cover: passo 47, immagine 2 di 3 iPhone 15 Logic Board Replacement, Remove the upper connector cover: passo 47, immagine 3 di 3
    • Use your tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the upper connector cover.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  48. iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: passo 48, immagine 1 di 3 iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: passo 48, immagine 2 di 3 iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: passo 48, immagine 3 di 3
    • Use the tip of an opening pick to pry up and disconnect the antenna, front sensors, and front camera press connectors (three connectors in total).
    Chiedi a FixBot
    Aggiungi Commento
  49. iPhone 15 Logic Board Replacement, Remove the front camera and sensors: passo 49, immagine 1 di 2 iPhone 15 Logic Board Replacement, Remove the front camera and sensors: passo 49, immagine 2 di 2
    • Use tweezers or your fingers to pull the front camera and sensors out of their recess in the frame and remove them.
    Chiedi a FixBot
    Aggiungi Commento
  50. iPhone 15 Logic Board Replacement, Disconnect the earpiece speaker: passo 50, immagine 1 di 2 iPhone 15 Logic Board Replacement, Disconnect the earpiece speaker: passo 50, immagine 2 di 2
    • Use the tip of an opening pick to pry up and disconnect the earpiece speaker press connector.
    Chiedi a FixBot
    Aggiungi Commento
  51. iPhone 15 Logic Board Replacement, Unfasten the earpiece speaker: passo 51, immagine 1 di 1
    • Use a Phillips #000 driver to remove the five screws securing the earpiece speaker:
    • Two 1.1 mm‑long screws
    • Three 1.6 mm‑long screws
    Chiedi a FixBot
    Aggiungi Commento
  52. iPhone 15 Logic Board Replacement, Remove the earpiece speaker: passo 52, immagine 1 di 3 iPhone 15 Logic Board Replacement, Remove the earpiece speaker: passo 52, immagine 2 di 3 iPhone 15 Logic Board Replacement, Remove the earpiece speaker: passo 52, immagine 3 di 3
    • Use tweezers or your fingers to lift and pull the earpiece speaker away from the top of the phone to free the gasket from the frame.
    • Remove the earpiece speaker.
    Chiedi a FixBot
    Aggiungi Commento
  53. iPhone 15 Logic Board Replacement, Separate the battery cable: passo 53, immagine 1 di 3 iPhone 15 Logic Board Replacement, Separate the battery cable: passo 53, immagine 2 di 3 iPhone 15 Logic Board Replacement, Separate the battery cable: passo 53, immagine 3 di 3
    • Light adhesive secures the battery cable to the logic board.
    • Slide an opening pick under the battery cable to separate it from the logic board.
    • Be careful not to crease the cable or dent the battery with your tool.
    Chiedi a FixBot
    Aggiungi Commento
  54. iPhone 15 Logic Board Replacement, Disconnect the volume buttons: passo 54, immagine 1 di 2 iPhone 15 Logic Board Replacement, Disconnect the volume buttons: passo 54, immagine 2 di 2
    • Use the tip of an opening pick to pry up and disconnect the volume buttons press connector.
    Chiedi a FixBot
    Aggiungi Commento
  55. iPhone 15 Logic Board Replacement, Disconnect the power button: passo 55, immagine 1 di 2 iPhone 15 Logic Board Replacement, Disconnect the power button: passo 55, immagine 2 di 2
    • Disconnect the power button press connector.
    Chiedi a FixBot
    Aggiungi Commento
  56. iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: passo 56, immagine 1 di 3 iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: passo 56, immagine 2 di 3 iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: passo 56, immagine 3 di 3
    • Disconnect the rear cameras and antenna press connectors (three connectors in total).
    Chiedi a FixBot
    Aggiungi Commento
  57. iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: passo 57, immagine 1 di 3 iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: passo 57, immagine 2 di 3 iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: passo 57, immagine 3 di 3
    • Disconnect the eSIM, Taptic Engine, and charging port press connectors (three connectors in total).
    Chiedi a FixBot
    Aggiungi Commento
  58. iPhone 15 Logic Board Replacement, Unfasten the logic board: passo 58, immagine 1 di 2 iPhone 15 Logic Board Replacement, Unfasten the logic board: passo 58, immagine 2 di 2
    Standoff Screwdriver for iPhones
    $5.49
    • Use your standoff driver to remove the five standoff screws securing the logic board:
    • One 2.9 mm‑long screw
    • One 3.9 mm‑long screw
    • Three 3.5 mm‑long screws
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
    Chiedi a FixBot
    Aggiungi Commento
  59. iPhone 15 Logic Board Replacement, Remove the logic board: passo 59, immagine 1 di 3 iPhone 15 Logic Board Replacement, Remove the logic board: passo 59, immagine 2 di 3 iPhone 15 Logic Board Replacement, Remove the logic board: passo 59, immagine 3 di 3
    • Grip the top edge of the logic board and gently pull it out from under the cables.
    • Remove the logic board.
    • During reassembly, make sure all nine press connectors (including the small volume buttons cable) are above the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  60. iPhone 15 Logic Board Replacement, End of disassembly: passo 60, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Chiedi a FixBot
    Aggiungi Commento
  61. iPhone 15 Logic Board Replacement, Place the logic board: passo 61, immagine 1 di 2 iPhone 15 Logic Board Replacement, Place the logic board: passo 61, immagine 2 di 2
    • Slide the logic board into its slot in the frame, making sure the nine press connectors are above the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  62. iPhone 15 Logic Board Replacement, Install the logic board screws: passo 62, immagine 1 di 2 iPhone 15 Logic Board Replacement, Install the logic board screws: passo 62, immagine 2 di 2
    $5.49
    • Use your standoff driver to install the five standoff screws securing the logic board:
    Chiedi a FixBot
    Aggiungi Commento
  63. iPhone 15 Logic Board Replacement, Connect the press connectors: passo 63, immagine 1 di 3 iPhone 15 Logic Board Replacement, Connect the press connectors: passo 63, immagine 2 di 3 iPhone 15 Logic Board Replacement, Connect the press connectors: passo 63, immagine 3 di 3
    • Use your spudger or your fingers to connect the eight press connectors:
    • The power button
    • The volume button
    • The rear cameras and antenna (three connectors in total)
    • The eSIM
    • The Taptic Engine
    • The charging port
    • Don't connect the battery press connector yet.
    Chiedi a FixBot
    Aggiungi Commento
  64. iPhone 15 Logic Board Replacement, Place the earpiece speaker: passo 64, immagine 1 di 2 iPhone 15 Logic Board Replacement, Place the earpiece speaker: passo 64, immagine 2 di 2
    • Align the gasket on the earpiece speaker with its sound channel.
    • Press the earpiece speaker onto the frame so it lies flat.
    Chiedi a FixBot
    Aggiungi Commento
  65. iPhone 15 Logic Board Replacement, Install the earpiece speaker screws: passo 65, immagine 1 di 1
    • Use a Phillips #000 driver to install the five screws securing the earpiece speaker:
    Chiedi a FixBot
    Aggiungi Commento
  66. iPhone 15 Logic Board Replacement, Install the front camera assembly: passo 66, immagine 1 di 3 iPhone 15 Logic Board Replacement, Install the front camera assembly: passo 66, immagine 2 di 3 iPhone 15 Logic Board Replacement, Install the front camera assembly: passo 66, immagine 3 di 3
    • Slide the front camera assembly into its recess in the frame.
    • Set the assembly down so it lies flat.
    Chiedi a FixBot
    Aggiungi Commento
  67. iPhone 15 Logic Board Replacement, Connect the assemblies: passo 67, immagine 1 di 3 iPhone 15 Logic Board Replacement, Connect the assemblies: passo 67, immagine 2 di 3 iPhone 15 Logic Board Replacement, Connect the assemblies: passo 67, immagine 3 di 3
    • Use the flat end of a spudger or your finger to connect the front camera and earpiece speaker press connectors.
    • If the iPhone has a mmWave antenna, connect it as well.
    Chiedi a FixBot
    Aggiungi Commento
  68. iPhone 15 Logic Board Replacement, Install the upper connector cover: passo 68, immagine 1 di 3 iPhone 15 Logic Board Replacement, Install the upper connector cover: passo 68, immagine 2 di 3 iPhone 15 Logic Board Replacement, Install the upper connector cover: passo 68, immagine 3 di 3
    • Place the cover over the logic board and align its screw holes.
    • Use your tri-point Y000 driver to install the two 1.3 mm‑long screws securing the upper connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  69. iPhone 15 Logic Board Replacement, Remove the back glass adhesive: passo 69, immagine 1 di 2 iPhone 15 Logic Board Replacement, Remove the back glass adhesive: passo 69, immagine 2 di 2
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
    • Use the tweezers to pull the adhesive off of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  70. iPhone 15 Logic Board Replacement: passo 70, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 70, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 70, immagine 3 di 3
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    Chiedi a FixBot
    Aggiungi Commento
  71. iPhone 15 Logic Board Replacement, Orient the adhesive: passo 71, immagine 1 di 3 iPhone 15 Logic Board Replacement, Orient the adhesive: passo 71, immagine 2 di 3 iPhone 15 Logic Board Replacement, Orient the adhesive: passo 71, immagine 3 di 3
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the rear camera to make sure the adhesive is oriented correctly.
    • Your adhesive may look slightly different.
    Chiedi a FixBot
    Aggiungi Commento
  72. iPhone 15 Logic Board Replacement, Apply the adhesive: passo 72, immagine 1 di 3 iPhone 15 Logic Board Replacement, Apply the adhesive: passo 72, immagine 2 di 3 iPhone 15 Logic Board Replacement, Apply the adhesive: passo 72, immagine 3 di 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
    • Hold the liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
    Chiedi a FixBot
    Aggiungi Commento
  73. iPhone 15 Logic Board Replacement: passo 73, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 73, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 73, immagine 3 di 3
    • When the adhesive is aligned, use the flat end of a spudger or your finger to press it down firmly along the bottom edge.
    Chiedi a FixBot
    Aggiungi Commento
  74. iPhone 15 Logic Board Replacement: passo 74, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 74, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 74, immagine 3 di 3
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  75. iPhone 15 Logic Board Replacement, Press the adhesive into place: passo 75, immagine 1 di 3 iPhone 15 Logic Board Replacement, Press the adhesive into place: passo 75, immagine 2 di 3 iPhone 15 Logic Board Replacement, Press the adhesive into place: passo 75, immagine 3 di 3
    • Make sure the liner is aligned properly by checking that all spring contacts and the rear camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    • Be careful not to touch the spring contacts sticking through the pink liner.
    Chiedi a FixBot
    Aggiungi Commento
  76. iPhone 15 Logic Board Replacement, Remove the top liner: passo 76, immagine 1 di 3 iPhone 15 Logic Board Replacement, Remove the top liner: passo 76, immagine 2 di 3 iPhone 15 Logic Board Replacement, Remove the top liner: passo 76, immagine 3 di 3
    • Remove the top adhesive liner.
    • Depending on your adhesive, your liner might be split into multiple parts or be a single piece.
    Chiedi a FixBot
    Aggiungi Commento
  77. iPhone 15 Logic Board Replacement, Prop up the back glass: passo 77, immagine 1 di 3 iPhone 15 Logic Board Replacement, Prop up the back glass: passo 77, immagine 2 di 3 iPhone 15 Logic Board Replacement, Prop up the back glass: passo 77, immagine 3 di 3
    • Prop up the back glass along the right edge of the iPhone, using a box or similar sturdy object to support the screen.
    • Use the flat end of a spudger or your finger to connect the wireless charging coil press connector, then the battery press connector.
    Chiedi a FixBot
    Aggiungi Commento
  78. iPhone 15 Logic Board Replacement, Place the middle connector cover: passo 78, immagine 1 di 2 iPhone 15 Logic Board Replacement, Place the middle connector cover: passo 78, immagine 2 di 2
    • Place the middle connector cover over the wireless charging coil press connector so it slightly overhangs the slot on the logic board for the bottom clip.
    Chiedi a FixBot
    Aggiungi Commento
  79. iPhone 15 Logic Board Replacement: passo 79, immagine 1 di 2 iPhone 15 Logic Board Replacement: passo 79, immagine 2 di 2
    • Use your finger to press the cover down on the logic board.
    • While pressing it down, slide the cover upward so both metal clips slot into their spots in the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  80. iPhone 15 Logic Board Replacement, Place the lower connector cover: passo 80, immagine 1 di 3 iPhone 15 Logic Board Replacement, Place the lower connector cover: passo 80, immagine 2 di 3 iPhone 15 Logic Board Replacement, Place the lower connector cover: passo 80, immagine 3 di 3
    • Use tweezers to hook the top of the lower connector cover into its slot on the logic board.
    • Lay the lower connector cover over the press connectors.
    Chiedi a FixBot
    Aggiungi Commento
  81. iPhone 15 Logic Board Replacement, Install the cover screws: passo 81, immagine 1 di 2 iPhone 15 Logic Board Replacement, Install the cover screws: passo 81, immagine 2 di 2
    • Use a tri-point Y000 screwdriver to install the 0.9 mm‑long screw securing the middle connector cover.
    • Use a tri-point Y000 screwdriver to install the two 1.3 mm‑long screws securing the lower connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  82. iPhone 15 Logic Board Replacement, Remove the final adhesive liners: passo 82, immagine 1 di 2 iPhone 15 Logic Board Replacement, Remove the final adhesive liners: passo 82, immagine 2 di 2
    • Use tweezers or your fingers to separate the pull tabs at the bottom of the frame, near the charging port.
    Chiedi a FixBot
    Aggiungi Commento
  83. iPhone 15 Logic Board Replacement: passo 83, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 83, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 83, immagine 3 di 3
    • Remove the narrow liner covering the adhesive along the left and top edges of the frame.
    Chiedi a FixBot
    Aggiungi Commento
  84. iPhone 15 Logic Board Replacement: passo 84, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 84, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 84, immagine 3 di 3
    • Hold the back glass over the phone without letting it touch the adhesive, so you can access the remaining liners along the right edge of the phone.
    • Use a pair of tweezers or your fingers to remove the remaing liners along the right edge of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  85. iPhone 15 Logic Board Replacement, Install the back glass: passo 85, immagine 1 di 3 iPhone 15 Logic Board Replacement, Install the back glass: passo 85, immagine 2 di 3 iPhone 15 Logic Board Replacement, Install the back glass: passo 85, immagine 3 di 3
    • Lay the back glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all the clips.
    Chiedi a FixBot
    Aggiungi Commento
  86. iPhone 15 Logic Board Replacement, Heat the back glass: passo 86, immagine 1 di 2 iPhone 15 Logic Board Replacement, Heat the back glass: passo 86, immagine 2 di 2
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass.
    Chiedi a FixBot
    Aggiungi Commento
  87. iPhone 15 Logic Board Replacement, Remove the screen adhesive: passo 87, immagine 1 di 3 iPhone 15 Logic Board Replacement, Remove the screen adhesive: passo 87, immagine 2 di 3 iPhone 15 Logic Board Replacement, Remove the screen adhesive: passo 87, immagine 3 di 3
    • This is a good point to test your repair before sealing up your phone. Connect the screen, power on your phone, and make sure it works as expected. Power it back down and continue reassembly.
    • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
    • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
    Chiedi a FixBot
    Aggiungi Commento
  88. iPhone 15 Logic Board Replacement: passo 88, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 88, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 88, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
  89. iPhone 15 Logic Board Replacement, Orient the adhesive: passo 89, immagine 1 di 3 iPhone 15 Logic Board Replacement, Orient the adhesive: passo 89, immagine 2 di 3 iPhone 15 Logic Board Replacement, Orient the adhesive: passo 89, immagine 3 di 3
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
    Chiedi a FixBot
    Aggiungi Commento
  90. iPhone 15 Logic Board Replacement, Apply the adhesive: passo 90, immagine 1 di 3 iPhone 15 Logic Board Replacement, Apply the adhesive: passo 90, immagine 2 di 3 iPhone 15 Logic Board Replacement, Apply the adhesive: passo 90, immagine 3 di 3
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
    • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
    Chiedi a FixBot
    Aggiungi Commento
  91. iPhone 15 Logic Board Replacement: passo 91, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 91, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 91, immagine 3 di 3
    • When the adhesive is aligned, use the flat end of a spudger, or your finger, to press it down firmly along the bottom edge.
    Chiedi a FixBot
    Aggiungi Commento
  92. iPhone 15 Logic Board Replacement: passo 92, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 92, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 92, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
  93. iPhone 15 Logic Board Replacement, Press the adhesive into place: passo 93, immagine 1 di 3 iPhone 15 Logic Board Replacement, Press the adhesive into place: passo 93, immagine 2 di 3 iPhone 15 Logic Board Replacement, Press the adhesive into place: passo 93, immagine 3 di 3
    • Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
    • Be careful not to press on the camera, spring contacts, or other internal components.
    Chiedi a FixBot
    Aggiungi Commento
  94. iPhone 15 Logic Board Replacement, Remove the top liner: passo 94, immagine 1 di 2 iPhone 15 Logic Board Replacement, Remove the top liner: passo 94, immagine 2 di 2
    • Insert the point of a spudger under the top liner's hole at the bottom of the frame.
    • Pry up to separate the liner from the frame—enough to grip it with your fingers.
    • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners under it.
    Chiedi a FixBot
    Aggiungi Commento
  95. iPhone 15 Logic Board Replacement: passo 95, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 95, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 95, immagine 3 di 3
    • Peel back the top liner and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  96. iPhone 15 Logic Board Replacement, Prop up the screen: passo 96, immagine 1 di 1
    • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
    Chiedi a FixBot
    Aggiungi Commento
  97. iPhone 15 Logic Board Replacement, Connect the screen: passo 97, immagine 1 di 2 iPhone 15 Logic Board Replacement, Connect the screen: passo 97, immagine 2 di 2
    • Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
    Chiedi a FixBot
    Aggiungi Commento
  98. iPhone 15 Logic Board Replacement: passo 98, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 98, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 98, immagine 3 di 3
    • Insert the top of the screen connector cover into its slot in the frame and lay it over the press connector.
    Chiedi a FixBot
    Aggiungi Commento
  99. iPhone 15 Logic Board Replacement: passo 99, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 99, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 99, immagine 3 di 3
    • Insert the front sensor connector cover into its slot in the frame at a 90‑degree angle vertically.
    • Lay the cover over the press connector.
    Chiedi a FixBot
    Aggiungi Commento
  100. iPhone 15 Logic Board Replacement, Install the cover screws: passo 100, immagine 1 di 2 iPhone 15 Logic Board Replacement, Install the cover screws: passo 100, immagine 2 di 2
    • Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
    Chiedi a FixBot
    Aggiungi Commento
  101. iPhone 15 Logic Board Replacement, Remove the final adhesive liners: passo 101, immagine 1 di 2 iPhone 15 Logic Board Replacement, Remove the final adhesive liners: passo 101, immagine 2 di 2
    • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
    • Use a spudger, or your fingers, to separate the pull tabs at the bottom right corner of the frame.
    Chiedi a FixBot
    Aggiungi Commento
  102. iPhone 15 Logic Board Replacement: passo 102, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 102, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 102, immagine 3 di 3
    • Remove the narrow liner covering the adhesive along the right and top edges of the frame.
    Chiedi a FixBot
    Aggiungi Commento
  103. iPhone 15 Logic Board Replacement: passo 103, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 103, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 103, immagine 3 di 3
    • Remove the liner along the bottom edge of the frame.
    Chiedi a FixBot
    Aggiungi Commento
  104. iPhone 15 Logic Board Replacement: passo 104, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 104, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 104, immagine 3 di 3
    • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the phone.
    • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  105. iPhone 15 Logic Board Replacement, Place the screen: passo 105, immagine 1 di 3 iPhone 15 Logic Board Replacement, Place the screen: passo 105, immagine 2 di 3 iPhone 15 Logic Board Replacement, Place the screen: passo 105, immagine 3 di 3
    • Lay the screen straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the screen to engage all clips.
    Chiedi a FixBot
    Aggiungi Commento
  106. iPhone 15 Logic Board Replacement, Heat the screen: passo 106, immagine 1 di 2 iPhone 15 Logic Board Replacement, Heat the screen: passo 106, immagine 2 di 2
    • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
    Chiedi a FixBot
    Aggiungi Commento
  107. iPhone 15 Logic Board Replacement, Press the screen: passo 107, immagine 1 di 3 iPhone 15 Logic Board Replacement, Press the screen: passo 107, immagine 2 di 3 iPhone 15 Logic Board Replacement, Press the screen: passo 107, immagine 3 di 3
    • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    Chiedi a FixBot
    Aggiungi Commento
  108. iPhone 15 Logic Board Replacement: passo 108, immagine 1 di 2 iPhone 15 Logic Board Replacement: passo 108, immagine 2 di 2
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    Chiedi a FixBot
    Aggiungi Commento
  109. iPhone 15 Logic Board Replacement: passo 109, immagine 1 di 3 iPhone 15 Logic Board Replacement: passo 109, immagine 2 di 3 iPhone 15 Logic Board Replacement: passo 109, immagine 3 di 3
    • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Stack them to a consistent height taller than the camera bump.
    Chiedi a FixBot
    Aggiungi Commento
  110. iPhone 15 Logic Board Replacement: passo 110, immagine 1 di 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    Chiedi a FixBot
    Aggiungi Commento
  111. iPhone 15 Logic Board Replacement, Install the pentalobe screws: passo 111, immagine 1 di 2 iPhone 15 Logic Board Replacement, Install the pentalobe screws: passo 111, immagine 2 di 2
    • Use a P2 pentalobe driver to install the two 7.7 mm‑long screws on either side of the charging port.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Clay Eickemeyer
Membro da: 09/19/22
104.318 Reputazione
472 guide realizzate
Guide Team Membro di Guide Team
Staff
10 Membri
17.854 guide realizzate
1Commento della guida
You can remove the logic board without removing the screen if you carefully flip the logic board over during removal.
Finn Hagard - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 38
Ultimi 7 giorni: 356
Ultimi 30 giorni: 1,489
Tutti i Tempi: 24,077
