Introduzione
Follow this guide to remove or replace the volume button cable on an iPad mini 5 Wi-Fi. You may need to do this repair if the volume buttons have stopped working.
Note that this guide is for replacing the internal volume button cable and switch assembly, not the external metal button faces themselves.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Cosa ti serve
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Leave the opening pick in the iPad slightly past the front-facing camera.
Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
To avoid stressing any cables, hold the screen perpendicular to the frame.
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the two 1.3 mm screws securing the display cable bracket.
Insert the flat end of a spudger under the display cable bracket and lift up to disconnect the battery press connector from the logic board.
Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge.
Rotate the display cable bracket toward the battery.
Use the pointed end of a spudger to disconnect the digitizer press connector from the logic board.
Don't remove the black tape on the left, right, and upper edges of the display. These hold the display to the front glass.
Use a pair of tweezers to lift up the tape covering the press connector cover screws.
Use a Phillips screwdriver to remove the three screws securing the press connector cover:
One 1.9 mm screw
Two 1.3 mm screws
Use a pair of tweezers to remove the press connector cover.
Use the pointed end of a spudger to disconnect the volume control press connector.
Use a Phillips screwdriver to remove the two 1.9 mm screws securing the volume control bracket.
Use an opening pick to cut through the adhesive securing the volume button cable to the bracket.
Remove the volume button cable from the bracket.
Remove any remaining adhesive and residue from the bracket.
If your part doesn't come with adhesive preinstalled:
Follow this guide if you are using a pre-cut adhesive card. Follow this guide if you are using custom-cut adhesives.
Place the volume button cable onto the bracket and press firmly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 5 Answers community for help.
