Salta al contenuto principale
Samsung Galaxy S24 Plus Back Cover Replacement
Cosa ti serve
    1. Samsung Galaxy S24 Plus Back Cover Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 2 Samsung Galaxy S24 Plus Back Cover Replacement, Prepare your phone for disassembly: passo 1, immagine 2 di 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
      • Unplug any cables from your phone.
      • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Galaxy S24 Plus Back Cover Replacement, Heat the right edge: passo 2, immagine 1 di 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Galaxy S24 Plus Back Cover Replacement, Insert an opening pick: passo 3, immagine 1 di 3 Samsung Galaxy S24 Plus Back Cover Replacement, Insert an opening pick: passo 3, immagine 2 di 3 Samsung Galaxy S24 Plus Back Cover Replacement, Insert an opening pick: passo 3, immagine 3 di 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung Galaxy S24 Plus Back Cover Replacement, Separate the right adhesive: passo 4, immagine 1 di 3 Samsung Galaxy S24 Plus Back Cover Replacement, Separate the right adhesive: passo 4, immagine 2 di 3 Samsung Galaxy S24 Plus Back Cover Replacement, Separate the right adhesive: passo 4, immagine 3 di 3
      • Slide the pick back and forth along the right edge to separate the adhesive.
      • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
      Chiedi a FixBot
      Aggiungi Commento
    4. Samsung Galaxy S24 Plus Back Cover Replacement, Heat the bottom edge: passo 5, immagine 1 di 1
      • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
      Chiedi a FixBot
      Aggiungi Commento
    5. Samsung Galaxy S24 Plus Back Cover Replacement, Separate the corner adhesive: passo 6, immagine 1 di 2 Samsung Galaxy S24 Plus Back Cover Replacement, Separate the corner adhesive: passo 6, immagine 2 di 2
      • Rotate the opening pick around the bottom right corner to separate the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    6. Samsung Galaxy S24 Plus Back Cover Replacement, Separate the bottom adhesive: passo 7, immagine 1 di 2 Samsung Galaxy S24 Plus Back Cover Replacement, Separate the bottom adhesive: passo 7, immagine 2 di 2
      • Insert a second pick at the bottom right corner.
      • Slide the opening pick to the bottom left corner to separate the adhesive.
      • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
      Chiedi a FixBot
      Aggiungi Commento
    7. Samsung Galaxy S24 Plus Back Cover Replacement, Heat the left edge: passo 8, immagine 1 di 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Chiedi a FixBot
      Aggiungi Commento
    8. Samsung Galaxy S24 Plus Back Cover Replacement, Separate the corner adhesive: passo 9, immagine 1 di 2 Samsung Galaxy S24 Plus Back Cover Replacement, Separate the corner adhesive: passo 9, immagine 2 di 2
      • Rotate the opening pick around the bottom left corner to separate the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    9. Samsung Galaxy S24 Plus Back Cover Replacement, Separate the left adhesive: passo 10, immagine 1 di 2 Samsung Galaxy S24 Plus Back Cover Replacement, Separate the left adhesive: passo 10, immagine 2 di 2
      • Insert a third opening pick at the bottom left corner.
      • Slide the pick toward the top left corner to separate the adhesive.
      • Leave the pick near the top left corner to prevent the adhesive from resealing.
      Chiedi a FixBot
      Aggiungi Commento
    10. Samsung Galaxy S24 Plus Back Cover Replacement, Heat the top edge: passo 11, immagine 1 di 1
      • Apply a heated iOpener to the top edge of the back cover for two minutes.
      Chiedi a FixBot
      Aggiungi Commento
    11. Samsung Galaxy S24 Plus Back Cover Replacement, Separate the corner adhesive: passo 12, immagine 1 di 2 Samsung Galaxy S24 Plus Back Cover Replacement, Separate the corner adhesive: passo 12, immagine 2 di 2
      • Rotate the opening pick around the top left corner to separate the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    12. Samsung Galaxy S24 Plus Back Cover Replacement, Separate the top adhesive: passo 13, immagine 1 di 2 Samsung Galaxy S24 Plus Back Cover Replacement, Separate the top adhesive: passo 13, immagine 2 di 2
      • Insert a fourth opening pick at the top left corner.
      • Slide the pick toward the top right corner to separate the adhesive.
      • Leave the pick near the top right corner to prevent the adhesive from resealing.
      Chiedi a FixBot
      Aggiungi Commento
    13. Samsung Galaxy S24 Plus Back Cover Replacement, Separate the rear mic adhesive: passo 14, immagine 1 di 2 Samsung Galaxy S24 Plus Back Cover Replacement, Separate the rear mic adhesive: passo 14, immagine 2 di 2
      • There's a square of adhesive around the rear microphone, just above the flash.
      • Line up the tip of an opening pick with the flash.
      • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
      • Keep sliding the pick toward the bottom of the phone while gently lifting the cover until the cover is free of the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    14. Samsung Galaxy S24 Plus Back Cover Replacement, Remove the back cover: passo 15, immagine 1 di 2 Samsung Galaxy S24 Plus Back Cover Replacement, Remove the back cover: passo 15, immagine 2 di 2
      • Grab and remove the back cover.
      • If the back cover is not lifting easily, use an opening pick to separate any adhesive that may have resealed.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Retaining water resistance after the repair will depend on how well you reapply the back cover adhesive, but your device will lose its IP (Ingress Protection) rating.
      • Use tweezers or your fingers to remove all adhesive from the back cover and the phone. Use heat or isopropyl alcohol (90% or greater) and a coffee filter or lint-free cloth if you're having trouble removing the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Guide Team Membro di Guide Team
Staff
10 Membri
26.090 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 11
Ultimi 7 giorni: 74
Ultimi 30 giorni: 274
Tutti i Tempi: 3,822
