Salta al contenuto principale
Samsung Galaxy Note10 Front-Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Note10 Front-Facing Camera Replacement, Heat the back panel: passo 1, immagine 1 di 1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Galaxy Note10 Front-Facing Camera Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Galaxy Note10 Front-Facing Camera Replacement, Begin to slice the adhesive: passo 3, immagine 1 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement, Begin to slice the adhesive: passo 3, immagine 2 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement, Begin to slice the adhesive: passo 3, immagine 3 di 3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Do not insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Galaxy Note10 Front-Facing Camera Replacement, Slice the left side adhesive: passo 4, immagine 1 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement, Slice the left side adhesive: passo 4, immagine 2 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement, Slice the left side adhesive: passo 4, immagine 3 di 3
    • Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Galaxy Note10 Front-Facing Camera Replacement, Slice the top side adhesive: passo 5, immagine 1 di 1
    • Prepare an iOpener and apply it to the top edge of the phone for one minute.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 6, immagine 1 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 6, immagine 2 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 6, immagine 3 di 3
    • Insert a third opening pick into the gap on the top edge of the phone.
    • Slide the opening pick to the top right corner, slicing the adhesive.
    • Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Galaxy Note10 Front-Facing Camera Replacement, Slice the right side adhesive: passo 7, immagine 1 di 1
    • Prepare an iOpener and apply it to the right edge of the phone for one minute.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 8, immagine 1 di 2 Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 8, immagine 2 di 2
    • Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive.
    • The back panel will begin to separate from the phone as you get closer to the bottom edge.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Galaxy Note10 Front-Facing Camera Replacement, Lift off the back panel: passo 9, immagine 1 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement, Lift off the back panel: passo 9, immagine 2 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement, Lift off the back panel: passo 9, immagine 3 di 3
    • Lift up and remove the back panel.
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung Galaxy Note10 Front-Facing Camera Replacement, Lift up the metal cover: passo 10, immagine 1 di 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
    Chiedi a FixBot
    Aggiungi Commento
  11. Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 11, immagine 1 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 11, immagine 2 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 11, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
    Chiedi a FixBot
    Aggiungi Commento
  12. Samsung Galaxy Note10 Front-Facing Camera Replacement, Disconnect the battery: passo 12, immagine 1 di 2 Samsung Galaxy Note10 Front-Facing Camera Replacement, Disconnect the battery: passo 12, immagine 2 di 2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  13. Samsung Galaxy Note10 Front-Facing Camera Replacement, Disconnect the wireless charging coil: passo 13, immagine 1 di 2 Samsung Galaxy Note10 Front-Facing Camera Replacement, Disconnect the wireless charging coil: passo 13, immagine 2 di 2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  14. Samsung Galaxy Note10 Front-Facing Camera Replacement, Remove the wireless charging coil: passo 14, immagine 1 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement, Remove the wireless charging coil: passo 14, immagine 2 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement, Remove the wireless charging coil: passo 14, immagine 3 di 3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
    Chiedi a FixBot
    Aggiungi Commento
  15. Samsung Galaxy Note10 Front-Facing Camera Replacement, Front-Facing Camera: passo 15, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four 4 mm screws securing the top plastic cover.
    Chiedi a FixBot
    Aggiungi Commento
  16. Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 16, immagine 1 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 16, immagine 2 di 3 Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 16, immagine 3 di 3
    • Use a pair of tweezers to pivot the top plastic cover up and off of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  17. Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 17, immagine 1 di 2 Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 17, immagine 2 di 2
    • Use the pointed end of a spudger to pry the front-facing camera connector straight up from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  18. Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 18, immagine 1 di 2 Samsung Galaxy Note10 Front-Facing Camera Replacement: passo 18, immagine 2 di 2
    • Remove the front-facing camera.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Carsten Frauenheim
Membro da: 03/10/20
165.790 Reputazione
439 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
26.050 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 38
Tutti i Tempi: 1,282
