Salta al contenuto principale
Microsoft Surface Pro 6 Volume and Power Buttons Replacement
Cosa ti serve
  1. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Heat the screen: passo 1, immagine 1 di 1
    • Completely power off the Surface before you begin disassembly.
    • If the screen's glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass. Lay overlapping strips of clear packing tape over the display until all the glass is covered. Wear safety glasses to protect your eyes.
    • Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used for more heat, but be careful not to overheat the Surface—the screen and internal battery are susceptible to heat damage.
    Chiedi a FixBot
    Aggiungi Commento
  2. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Take note of the adhesive layout: passo 2, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Take note of the adhesive layout: passo 2, immagine 2 di 2
    • Take note of the screen adhesive layout before continuing:
    • These areas only contain adhesive and are safe to cut.
    • The display board and flex cables sit here close to the edge. Cut very carefully and do not insert the pick as deep under the display.
    • Fragile antenna cables lie under this part of the screen. Carefully follow the procedure to avoid damaging them. The adhesive is also the thickest here.
    Chiedi a FixBot
    Aggiungi Commento
  3. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Insert an opening pick into the speaker opening: passo 3, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Insert an opening pick into the speaker opening: passo 3, immagine 2 di 2
    • Insert an opening pick into the speaker opening on the screen and slide the pick under the glass. Do not press the pick into the speaker grille, as the grille is easily torn.
    • Don't insert the opening pick any deeper than the black bezel on the side of the screen. Inserting the pick too far may damage the LCD.
    Chiedi a FixBot
    Aggiungi Commento
  4. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Slide an opening pick under the screen: passo 4, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Slide an opening pick under the screen: passo 4, immagine 2 di 2
    • Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
    Chiedi a FixBot
    Aggiungi Commento
  5. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Cut through the screen adhesive: passo 5, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Cut through the screen adhesive: passo 5, immagine 2 di 2
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  6. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 6, immagine 1 di 1
    • Reheat the iOpener and apply it to the bottom edge of the Surface's screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  7. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 7, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 7, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 7, immagine 3 di 3
    • Insert a new opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  8. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 8, immagine 1 di 1
    • Reheat the iOpener and apply it to the left edge of the Surface's screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  9. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 9, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 9, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 9, immagine 3 di 3
    • Insert a new opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Take care cutting under the lower 2.5 inches (65 mm) of the left edge. Do not insert the opening pick more than 1/8 inches (3 mm) here. The display cables sit near this part of the bezel and are easily damaged. Once past the display cable area, do not insert the pick past the bezel.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  10. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 10, immagine 1 di 1
    • Reheat the iOpener and apply it to the top edge of the Surface's screen for two minutes.
    • The adhesive is thickest along this edge, and you may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
    Chiedi a FixBot
    Aggiungi Commento
  11. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 11, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 11, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 11, immagine 3 di 3
    • Round the left corner with the opening pick and slide it along the top edge of the Surface. Stop when the pick is 2.75 inches (70 mm) away from the left edge.
    • The next 6 inches (15 cm) of the top edge of the case is covered by the left and right antennas, which sit between the case and the screen bezel. Follow the next steps carefully to avoid damaging the antennas.
    Chiedi a FixBot
    Aggiungi Commento
  12. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 12, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 12, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 12, immagine 3 di 3
    • Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
    • Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
    • Keep the pick parallel to the screen throughout the whole procedure so that it doesn't catch on the antennas. Do not press the pick against the case.
    • Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
    Chiedi a FixBot
    Aggiungi Commento
  13. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 13, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 13, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 13, immagine 3 di 3
    • Once you cut the adhesive over the antennas (8.5 inches, or 22 cm, away from the left edge), slide the pick the rest of the way along the top edge of the surface and round the top right corner to slice through any remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  14. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Open the Surface: passo 14, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Open the Surface: passo 14, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Open the Surface: passo 14, immagine 3 di 3
    • Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
    • Do not remove the screen yet. It is still connected to the motherboard by two cables.
    • Use an opening pick to cut through any remaining adhesive.
    • The flash lens may fall out of the Surface case. Keep track of the lens and return it to its cutout in the case during reassembly.
    Chiedi a FixBot
    Aggiungi Commento
  15. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 15, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 15, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 15, immagine 3 di 3
    • Lift the top of the screen assembly away from the case while sliding the bottom of the screen closer to the motherboard display connectors.
    • Gently lay the screen down on the case with the connectors facing up. Take care to avoid creasing the display cables.
    Chiedi a FixBot
    Aggiungi Commento
  16. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Disconnect the screen: passo 16, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Disconnect the screen: passo 16, immagine 2 di 2
    • Use an opening pick to pry up one edge of the EMI shield covering the display board.
    • Repeat this procedure at different points around the shield until it is free.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    Chiedi a FixBot
    Aggiungi Commento
  17. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 17, immagine 1 di 1
    • Lift the EMI shield away from the display board and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  18. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 18, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 18, immagine 2 di 2
    • Use the flat end of a spudger to pry the display interconnect cable straight up and out of its socket on the board.
    Chiedi a FixBot
    Aggiungi Commento
  19. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 19, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 19, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
    • Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
    • Repeat this procedure at different points around the shield until it is free. Remove the shield.
    Chiedi a FixBot
    Aggiungi Commento
  20. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 20, immagine 1 di 1
    • Pull the rest of the shield off of the digitizer connector and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  21. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 21, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 21, immagine 2 di 2
    • Use the tip of a spudger to pry the digitizer connector straight up and out of its socket on the screen.
    Chiedi a FixBot
    Aggiungi Commento
  22. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 22, immagine 1 di 1
    • Remove the screen assembly from the Surface.
    • During reassembly, pause here and follow this guide to replace the screen adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  23. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Disconnect the antenna support: passo 23, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Disconnect the antenna support: passo 23, immagine 2 di 2
    • Use the point of a spudger to pry the microphone connector straight up and out of its socket on the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  24. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Unscrew the antenna support: passo 24, immagine 1 di 1
    • Use a T5 Torx driver to remove the four screws securing the antenna support:
    • Three 4.5 mm screws
    • One 6 mm screw
    Chiedi a FixBot
    Aggiungi Commento
  25. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Remove the antenna support: passo 25, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Remove the antenna support: passo 25, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Remove the antenna support: passo 25, immagine 3 di 3
    • Use a spudger to lift the antenna support out of its recess in the Surface.
    • Remove the antenna support.
    Chiedi a FixBot
    Aggiungi Commento
  26. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Remove the heat sink shield: passo 26, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Remove the heat sink shield: passo 26, immagine 2 di 2
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
    • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
    • Take care not to puncture the battery with the tweezers while working on this shield.
    Chiedi a FixBot
    Aggiungi Commento
  27. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 27, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 27, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 27, immagine 3 di 3
    • Repeat the last step for each corner of the EMI shield covering the heat sink.
    Chiedi a FixBot
    Aggiungi Commento
  28. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 28, immagine 1 di 1
    • Remove the heat sink shield.
    Chiedi a FixBot
    Aggiungi Commento
  29. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Remove the heat sink: passo 29, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Remove the heat sink: passo 29, immagine 2 di 2
    • Remove the ten Torx screws securing the heat sink:
    • Six 2.6 mm-long T3 screws
    • Four 3.3 mm-long T5 screws
    • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
    • Screw 1
    • Screw 2
    • Screw 3
    • Screw 4
    Chiedi a FixBot
    Aggiungi Commento
  30. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 30, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 30, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 30, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
  31. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Disconnect the left speaker: passo 31, immagine 1 di 2 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Disconnect the left speaker: passo 31, immagine 2 di 2
    • Use the point of a spudger to lift the left speaker connector out of its socket on the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  32. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Disconnect the volume and power buttons: passo 32, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Disconnect the volume and power buttons: passo 32, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Disconnect the volume and power buttons: passo 32, immagine 3 di 3
    • Use the point of a spudger to flip up the small locking flap securing the volume and power button cable ZIF connector.
    • Slide the volume and power button cable straight out of its socket on the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  33. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Remove the left speaker assembly: passo 33, immagine 1 di 1
    • Use a T5 Torx driver to remove the two screws securing the left speaker:
    • One 6 mm screw
    • One 3.9 mm screw
    Chiedi a FixBot
    Aggiungi Commento
  34. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 34, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 34, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 34, immagine 3 di 3
    • Use a spudger to lift the right edge of the speaker so that it clears the motherboard and screw bosses.
    • With the right edge lifted, slide the speaker to the right, straight out of its recess in the case.
    Chiedi a FixBot
    Aggiungi Commento
  35. Microsoft Surface Pro 6 Volume and Power Buttons Replacement, Remove the volume and power button assembly: passo 35, immagine 1 di 1
    • Heat an iOpener and apply it to the long edge of the speaker assembly for two minutes to soften the adhesive securing the buttons.
    Chiedi a FixBot
    Aggiungi Commento
  36. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 36, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 36, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 36, immagine 3 di 3
    • Slide an opening pick under the volume and power button cable to separate the adhesive securing the cable to the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  37. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 37, immagine 1 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 37, immagine 2 di 3 Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 37, immagine 3 di 3
    • Slide an opening pick under the volume and power buttons to separate the adhesive securing the buttons to the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  38. Microsoft Surface Pro 6 Volume and Power Buttons Replacement: passo 38, immagine 1 di 1
    • Remove the volume and power buttons.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
Adam O'Camb
Membro da: 04/11/15
223.483 Reputazione
416 guide realizzate
1Commento della guida
cuanto cobran por cambiar el boton de encendido de Surface. se sumio
Daniel Perez - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 15
Ultimi 30 giorni: 67
Tutti i Tempi: 2,931
