Salta al contenuto principale
Microsoft Surface Pro 5 Screen Adhesive Replacement
Cosa ti serve
  1. Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: passo 1, immagine 1 di 3 Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: passo 1, immagine 2 di 3 Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: passo 1, immagine 3 di 3
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
    Chiedi a FixBot
    Aggiungi Commento
  2. Microsoft Surface Pro 5 Screen Adhesive Replacement, Apply the new adhesive: passo 2, immagine 1 di 2 Microsoft Surface Pro 5 Screen Adhesive Replacement, Apply the new adhesive: passo 2, immagine 2 di 2
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
    Chiedi a FixBot
    Aggiungi Commento
  3. Microsoft Surface Pro 5 Screen Adhesive Replacement, Install the display: passo 3, immagine 1 di 1
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro 6 answers community for help.
Altre 3 persone hanno completato questa guida.
Sam Omiotek
Membro da: 02/25/19
98.886 Reputazione
290 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 20
Ultimi 30 giorni: 76
Tutti i Tempi: 4,483
