Salta al contenuto principale
HP 14-dq5043cl Battery Replacement
Cosa ti serve
  1. HP 14-dq5043cl Battery Replacement, Lower Case: passo 1, immagine 1 di 2 HP 14-dq5043cl Battery Replacement, Lower Case: passo 1, immagine 2 di 2
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Remove the two rubber feet on the lower case.
    • If you intend to reuse the rubber feet: Use a hairdryer or iOpener to lightly heat the feet to loosen the adhesive that secures them prior to removal. Take care not to stretch out the rubber.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP 14-dq5043cl Battery Replacement: passo 2, immagine 1 di 1
    • Remove the six M2XL6 Phillips screws that secure the lower case.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP 14-dq5043cl Battery Replacement: passo 3, immagine 1 di 3 HP 14-dq5043cl Battery Replacement: passo 3, immagine 2 di 3 HP 14-dq5043cl Battery Replacement: passo 3, immagine 3 di 3
    • Insert a nylon spudger into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Remove the lower case.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP 14-dq5043cl Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the four Phillips screws that secure the battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP 14-dq5043cl Battery Replacement: passo 5, immagine 1 di 1
    • Grip the lower edge of the battery and pull it toward you to disconnect the blade-style battery connector.
    • Remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 23
Ultimi 30 giorni: 83
Tutti i Tempi: 925
