Salta al contenuto principale
Google Pixel Fold Flip Battery Replacement
Cosa ti serve
  1. Google Pixel Fold Flip Battery Replacement, Safety Precautions: passo 1, immagine 1 di 1
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel Fold Flip Battery Replacement, Remove the SIM card tray: passo 2, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Remove the SIM card tray: passo 2, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Remove the SIM card tray: passo 2, immagine 3 di 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • Press firmly to eject the SIM card tray.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel Fold Flip Battery Replacement, Heat the bottom edge: passo 3, immagine 1 di 1
    • Heat an iOpener and apply it to the bottom edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel Fold Flip Battery Replacement, Adhesive information: passo 4, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Adhesive information: passo 4, immagine 2 di 2
    • While you're waiting for the adhesive to soften, note the following:
    • The adhesive is under the dark black border surrounding the screen.
    • During the screen removal procedure, you only need to insert your opening pick as deep as the border.
    • Don't insert your pick any deeper, as you risk damaging the screen and internal components.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel Fold Flip Battery Replacement, Insert an opening pick: passo 5, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: passo 5, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: passo 5, immagine 3 di 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel Fold Flip Battery Replacement, Separate the bottom adhesive: passo 6, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Separate the bottom adhesive: passo 6, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Separate the bottom adhesive: passo 6, immagine 3 di 3
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the opening pick in the bottom right corner before continuing.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel Fold Flip Battery Replacement, Heat the right edge: passo 7, immagine 1 di 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel Fold Flip Battery Replacement, Separate the bottom right adhesive: passo 8, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Separate the bottom right adhesive: passo 8, immagine 2 di 2
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel Fold Flip Battery Replacement, Separate the right adhesive: passo 9, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Separate the right adhesive: passo 9, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Separate the right adhesive: passo 9, immagine 3 di 3
    • Insert a new opening pick in the bottom right corner.
    • Slide the opening pick toward the top right corner to separate the adhesive.
    • Leave the opening pick in the top right corner before continuing.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel Fold Flip Battery Replacement, Heat the top edge: passo 10, immagine 1 di 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel Fold Flip Battery Replacement, Separate the top right adhesive: passo 11, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Separate the top right adhesive: passo 11, immagine 2 di 2
    • Rotate the opening pick around the top right corner to separate its adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel Fold Flip Battery Replacement, Separate the top adhesive: passo 12, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Separate the top adhesive: passo 12, immagine 2 di 2
    • Insert a new opening pick in the top right corner.
    • Slide the opening pick toward the top left corner to separate its adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel Fold Flip Battery Replacement, Heat the left edge: passo 13, immagine 1 di 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel Fold Flip Battery Replacement, Separate the top left adhesive: passo 14, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Separate the top left adhesive: passo 14, immagine 2 di 2
    • The sharp corner is very fragile. Use plenty of heat and be very gentle around the corner during this step.
    • Angle your pick so it's as flat as possible to the screen.
    • Rotate the opening pick around the top left corner to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel Fold Flip Battery Replacement, Separate the left adhesive: passo 15, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Separate the left adhesive: passo 15, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Separate the left adhesive: passo 15, immagine 3 di 3
    • Insert a new opening pick in the top left corner.
    • Slide the opening pick toward the bottom left corner to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel Fold Flip Battery Replacement, Separate the bottom left adhesive: passo 16, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Separate the bottom left adhesive: passo 16, immagine 2 di 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel Fold Flip Battery Replacement, Adhesive information: passo 17, immagine 1 di 1
    • There's a small adhesive strip that secures the screen near the top right corner of the phone.
    • The next three steps will show you how to separate this adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel Fold Flip Battery Replacement, Heat the top right corner: passo 18, immagine 1 di 1
    • Heat an iOpener and apply it to the top right corner of the screen for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel Fold Flip Battery Replacement, Insert an opening pick: passo 19, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: passo 19, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: passo 19, immagine 3 di 3
    • Insert an opening pick under the right edge of the screen, near the top right corner.
    • Push the opening pick under the screen as far you can go without losing your grip.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel Fold Flip Battery Replacement, Separate the adhesive: passo 20, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Separate the adhesive: passo 20, immagine 2 di 2
    • Be very careful during this step, as you risk breaking the screen. Work slowly and apply more heat if necessary.
    • Twist the opening pick back and forth to separate the adhesive.
    • If you don't feel the adhesive separating, apply more heat or insert the pick at a different angle.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel Fold Flip Battery Replacement, Reposition the screen: passo 21, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Reposition the screen: passo 21, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Reposition the screen: passo 21, immagine 3 di 3
    • At this point, the screen should be separated from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Don't remove the screen yet, as it's still connected to the phone by a cable.
    • Swing the left edge of the screen up and over the right edge of the phone.
    • Let the screen rest next to the phone before continuing.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel Fold Flip Battery Replacement, Unfasten the bottom bracket: passo 22, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    FixMat
    $31.41
    • While the Pixel Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 Torx or T4 bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five 2.5 mm‑long screws securing the bottom bracket.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel Fold Flip Battery Replacement, Remove the bottom bracket: passo 23, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Remove the bottom bracket: passo 23, immagine 2 di 2
    • Use tweezers, or your fingers, to remove the bottom bracket.
    • During reassembly, make sure the bottom bracket is sitting in its two alignment pegs before refastening it.
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel Fold Flip Battery Replacement, Disconnect the flip battery: passo 24, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Disconnect the flip battery: passo 24, immagine 2 di 2
    • Don't pry against the battery during this step. Angle your spudger under the left or right edges of the press connector.
    • Use the flat end of a spudger to pry up and disconnect the flip battery press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel Fold Flip Battery Replacement, Disconnect the screen: passo 25, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Disconnect the screen: passo 25, immagine 2 di 2
    • Insert the point of a spudger under the short edge of the screen press connector facing the bottom of the phone.
    • Don't insert your spudger anywhere else, as you risk damaging surface-mounted components on the logic board.
    • Pry up to disconnect the screen press connector.
    Chiedi a FixBot
    Aggiungi Commento
  26. Google Pixel Fold Flip Battery Replacement, Remove the screen: passo 26, immagine 1 di 1
    • Remove the screen.
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Chiedi a FixBot
    Aggiungi Commento
  27. Google Pixel Fold Flip Battery Replacement, Reassembly information: passo 27, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Reassembly information: passo 27, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Reassembly information: passo 27, immagine 3 di 3
    Tesa 61395 Tape
    $8.95
    • During reassembly, perform the following:
    • If you're reusing your screen, use tweezers to remove big chunks of adhesive from the perimeter of the screen.
    • Repeat for any adhesive on the frame, including the small adhesive at the top right of the phone.
    • If your top right adhesive is still intact and sticky, you can reuse it.
    • Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
    • Follow this guide to replace your screen adhesive.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the screen to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  28. Google Pixel Fold Flip Battery Replacement, Disconnect the bottom interconnect cable: passo 28, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Disconnect the bottom interconnect cable: passo 28, immagine 2 di 2
    • Use a spudger to pry up and disconnect the bottom interconnect cable press connector.
    Chiedi a FixBot
    Aggiungi Commento
  29. Google Pixel Fold Flip Battery Replacement, Unfasten the lower board: passo 29, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Unfasten the lower board: passo 29, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the 2.2 mm‑long screw securing the lower board.
    • There's a magnet at the bottom right corner of phone. As you remove the nearby screw, it might stick to the magnet.
    • If you're having trouble inserting the screw, use tweezers to hold it in place while you screw in the first few threads.
    Chiedi a FixBot
    Aggiungi Commento
  30. Google Pixel Fold Flip Battery Replacement, Secure the cable: passo 30, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Secure the cable: passo 30, immagine 2 di 2
    • During the next step, keep the bottom interconnect cable out of the way using your hands or tape with light adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  31. Google Pixel Fold Flip Battery Replacement, Remove the lower board: passo 31, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Remove the lower board: passo 31, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Remove the lower board: passo 31, immagine 3 di 3
    • Use a spudger to pry up the lower board from its recess in the frame.
    • Remove the lower board.
    Chiedi a FixBot
    Aggiungi Commento
  32. Google Pixel Fold Flip Battery Replacement, Reassembly information: passo 32, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Reassembly information: passo 32, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Reassembly information: passo 32, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
  33. Google Pixel Fold Flip Battery Replacement, Heat the battery cable: passo 33, immagine 1 di 1
    • The battery cable is lightly adhered to the frame.
    • Heat an iOpener and apply it to the battery cable for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  34. Google Pixel Fold Flip Battery Replacement, Separate the adhesive: passo 34, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Separate the adhesive: passo 34, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Separate the adhesive: passo 34, immagine 3 di 3
    • Slide an opening pick under the battery cable to separate the adhesive.
    • Use tweezers, or your fingers, to move the battery cable upward to expose the stretch-release adhesive tab under it.
    Chiedi a FixBot
    Aggiungi Commento
  35. Google Pixel Fold Flip Battery Replacement, Adhesive information: passo 35, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Adhesive information: passo 35, immagine 2 di 2
    • Six stretch release adhesive strips secure the battery to the frame:
    • The three along the left edge are very difficult to remove. Work slowly and avoid pulling the strips at steep angles.
    • The three along the bottom are moderately difficult to remove.
    Chiedi a FixBot
    Aggiungi Commento
  36. Google Pixel Fold Flip Battery Replacement, Peel up the tabs: passo 36, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Peel up the tabs: passo 36, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Peel up the tabs: passo 36, immagine 3 di 3
    • Take care not to puncture or bend the battery with sharp tools—it can leak dangerous chemicals and/or catch fire.
    • Use tweezers to peel the black pull tabs from off the frame so you can grip them with your fingers.
    • Some of the black tabs aren't adhered and don't require peeling.
    Chiedi a FixBot
    Aggiungi Commento
  37. Google Pixel Fold Flip Battery Replacement, Remove the stretch release adhesive: passo 37, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Remove the stretch release adhesive: passo 37, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Remove the stretch release adhesive: passo 37, immagine 3 di 3
    • Pull each strip out slowly and steadily at a low angle. Give them plenty of time to stretch and un-stick from under the battery.
    • You can also wrap an adhesive strip around a spudger and "roll" it for a more consistent pull.
    • If any adhesive strips break off, try to retrieve them using your fingers or tweezers, and continue pulling—but don’t pry under the battery.
    • If you can't retrieve a strip, don't worry! Remove as much adhesive as possible and move to the next step for an alternate method.
    • Repeat for all six stretch release adhesive strips.
    Chiedi a FixBot
    Aggiungi Commento
  38. Google Pixel Fold Flip Battery Replacement, Apply isopropyl alcohol: passo 38, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Apply isopropyl alcohol: passo 38, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Apply isopropyl alcohol: passo 38, immagine 3 di 3
    • If all six of the stretch release adhesive strips separated cleanly, skip the next five steps. Otherwise, follow these steps for an alternate method.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Apply a few drops of high concentration (>90%) isopropyl alcohol in the gap between the frame and the left edge of the battery.
    Chiedi a FixBot
    Aggiungi Commento
  39. Google Pixel Fold Flip Battery Replacement, Tilt the phone: passo 39, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Tilt the phone: passo 39, immagine 2 di 2
    • Tilt the left side of the phone up to let the isopropyl alcohol flow under the battery.
    • Wait one minute for the alcohol to soften the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  40. Google Pixel Fold Flip Battery Replacement, Insert an opening pick: passo 40, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: passo 40, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: passo 40, immagine 3 di 3
    • Take care not to puncture or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Apply a suction cup to the battery, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the battery and the frame.
    Chiedi a FixBot
    Aggiungi Commento
  41. Google Pixel Fold Flip Battery Replacement, Rotate the pick: passo 41, immagine 1 di 2 Google Pixel Fold Flip Battery Replacement, Rotate the pick: passo 41, immagine 2 di 2
    • Rotate the opening pick so its long edge sits in the gap.
    Chiedi a FixBot
    Aggiungi Commento
  42. Google Pixel Fold Flip Battery Replacement, Pry up the battery: passo 42, immagine 1 di 3 Google Pixel Fold Flip Battery Replacement, Pry up the battery: passo 42, immagine 2 di 3 Google Pixel Fold Flip Battery Replacement, Pry up the battery: passo 42, immagine 3 di 3
    • Pull up on the suction cup with strong, steady force while also prying up with the opening pick to separate the battery from the frame.
    • If you're feeling a lot of resistance, apply a few more drops of isopropyl alcohol and try again.
    • Depending on the condition of your adhesive, you might need to repeat the alcohol and prying cycle a few times before the battery adhesive yields.
    Chiedi a FixBot
    Aggiungi Commento
  43. Google Pixel Fold Flip Battery Replacement, Remove the battery: passo 43, immagine 1 di 1
    Tesa 61395 Tape
    $8.95
    • If your bottom interconnect cable is still taped down, remove the tape now.
    • Lift the battery out its recess and remove it.
    • During reassembly, if your adhesive is still intact and sticky, you can reuse it. Otherwise, follow this guide to replace the adhesive with custom cut strips.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the battery to the frame.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
For optimal performance, calibrate your newly installed battery after completing this guide.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
239.396 Reputazione
1.171 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.947 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 26
Ultimi 30 giorni: 119
Tutti i Tempi: 2,967
